M3 S54 Cooling System Hi-Temp O-ring Kits!
    Bump...🤙
    Evolve Eventuri
      got my set and just wrapped up installing them. perfect fitment, and i'm sure they'll hold up great. thanks again!
        Welcome...👍
        Evolve Eventuri
          Might as well do it now while my engine is out. Ordered!
            Got it Thanks...😎
            Evolve Eventuri
              PayPal sent
                O-ring Kits back in stock!
                Evolve Eventuri
                  paypal sent
                  2003 BMW M3 6MT Coupe - TiAg/Black
                    Orders Shipped...👍
                    Evolve Eventuri
                      Bump...
                      Evolve Eventuri
                        Added 5 more O-rings to the Kit to cover the entire Cooling System! Now includes O-rings for the Heater Core Hoses and the Expansion Tank Hose.
                        Evolve Eventuri
                          Evolve Eventuri
                            Bump...👍
                            Evolve Eventuri
                              Complete set of Hi-Temp Silicone and Viton O-rings for the Entire S54 Cooling System. Power Steering and SMG Cap O-ring's also included.
                              Replace the factory Buna orings with higher quality Hi-temp Silicone and Viton O-rings. These O-rings have higher temperature rating and more resistant to compression set.
                              Click image for larger version  Name:	IMG_E0979.jpg Views:	64 Size:	107.1 KB ID:	59396
                              1- Temp Sensor- 1
                              2- Bleeder Screw- 1
                              3- Exp Tank Return Line- 1
                              4- Water Pump Lines- 2
                              5- Exp Tank Cap- 2
                              6- Exp Tank & Heater Core Hoses- 5
                              7- Radiator Hose Fittings- 2
                              8- Water Pump Pipe to Block- 2
                              9- Power Steering/SMG Caps- 2
                              10- Water Pump Tstat Housing- 1
                              Kit includes 2 squeeze tubes of Super Lube and 19 O-rings.
                              19 O-rings and Lube for $48 Shipped via Priority 3 Day.
                              Please send funds via PayPal as a gift or add $1.50 to cover the Fee to Mrdestny@yahoo.com
                              I have 100% Feedback on eBay so buy with confidence. Wolfn8tr on eBay: https://www.ebay.com/usr/wolfn8tr
                              Evolve Eventuri
                                Viton seals hold indefinitely at temperatures up to 400°F and can last up to 48 hours at temperatures up to 600°F. Buna is effective to 250°F. However, it can effectively seal mechanical objects at low temperatures to –22°F. Viton seals are rendered ineffective at temperatures below 5°F, with the material becoming hard and inflexible.
                                Is Viton unsuitable for colder climates then? In the Great Lakes, it routinely gets into the negative degrees F in the winter. Not that I'd be driving my M3 in those conditions, but unheated garages can definitely dip below 5°F. Can the material rebound from repeatedly cycling down below its low temperature limit, or is it permanently compromised if it has spent time under its limit?
                                2002 M3 Coupe 6MT
