Porsche 996 Calipers for BMW E46 M3 BBK Conversion
    Hi all,
    I did a 996 Brembo big brake conversion on my E46 M3 this summer, and was pleased with the results. Based on my experience, I am now offering used Brembo calipers for others to install on their M3s. There is a wealth of information on this forum about this conversion, but in short the benefits include improved braking performance, reduced unsprung weight and similar brake bias to stock.
    Part numbers for the calipers - 996.351.426, 996.351.425, 996.352.422, 996.352.421
    In order to pull this conversion off, you will need at a minimum
    • Set of 4 Porsche 996 Calipers
    • 996 Front Brake Pads
    • Rear Brake Pads – 996 rear pads if using Creations Motorsport (CM) rear caliper brackets, 996 rear or 987 Boxster front pads if using Rally Road (RR) rear brackets.
    • Front/Rear Adapter brackets – Creations Motorsport or Rally Road
    • Front/Rear Brake Lines – Creations Motorsport or Rally Road
    • ZCP front rotors (345 x 28 mm)
    • Front caliper machining (5.5 mm off mounting points)
    Optional but many people also go for
    • New caliper hardware
    • New bleeder valves
    • Professional Caliper rebuild/refinish, or DIY
    • ZCP rear rotors – stock non-ZCP rotors work, but people will go for ZCP rear rotors to get a drilled look all the way around
    • Brake pad wear sensors
    • New crossover lines
    • New rotor set screws (4 front, 4 rear)
    • Spacers w/extended lug bolts
    The total cost to pull this BBK conversion off is around $2k at a minimum (including an average cost of $800 for the calipers). Extra items, including rebuilding the calipers, rear ZCP rotors, new bleeder valves will bring the cost closer to $2.5k. If you want to get a professional to rebuild and powdercoat the calipers, the cost will end up closer to $3k for the full conversion.
    This is cheap in comparison to a real StopTech or Brembo BBK which runs $5k and up for a similar 4-piston front/rear kit.
    I am doing this in partnership with another fellow E46 M3 owner and member on here - Inizes. We share resources and knowledge, but operate independently for the most part. Caliper sets he has are listed below. Please see below and message him directly for calipers sets he has.
    Caliper sets currently available. When you inquire, please specify which set you are interested in.
    • Set #1 - 59k miles. Cleaned, inspected and tested. Good condition and does not necessarily need to be rebuilt. You can machine the front calipers and install them straight on to a car if you wish. Ideal for someone who wants to paint their calipers versus powder coating, since powder coating requires the calipers to be rebuilt. There are chips/scratches/scuffs in the finish as you would expect with a used set of calipers, but no notable damage to any of the aluminum castings. Comes with full set of caliper hardware, pads, dampeners and pad wear sensors. Asking $850 for this set. Local pickup in Columbus, OH or I will ship for $40 anywhere in the USA.
    • Click image for larger version  Name:	20200823_203631.jpg Views:	0 Size:	164.2 KB ID:	52455 Click image for larger version  Name:	20200823_203900.jpg Views:	0 Size:	141.1 KB ID:	52456 Click image for larger version  Name:	20200823_203930.jpg Views:	0 Size:	123.5 KB ID:	52448 Click image for larger version  Name:	20200823_203717.jpg Views:	0 Size:	71.3 KB ID:	52423 Click image for larger version  Name:	20200823_203657.jpg Views:	0 Size:	79.3 KB ID:	52424 Click image for larger version  Name:	20200823_203722.jpg Views:	0 Size:	92.8 KB ID:	52425 Click image for larger version  Name:	20200823_203733.jpg Views:	0 Size:	96.1 KB ID:	52426 Click image for larger version  Name:	20200823_203737.jpg Views:	0 Size:	115.1 KB ID:	52427 Click image for larger version  Name:	20200823_203816.jpg Views:	0 Size:	110.4 KB ID:	52428 Click image for larger version  Name:	20200823_204640.jpg Views:	0 Size:	238.2 KB ID:	52429 Click image for larger version  Name:	20200823_203918.jpg Views:	0 Size:	125.5 KB ID:	52430 Click image for larger version  Name:	20200823_203825.jpg Views:	0 Size:	127.4 KB ID:	52431 Click image for larger version  Name:	20200823_203828.jpg Views:	0 Size:	130.4 KB ID:	52432 Click image for larger version  Name:	20200823_203914.jpg Views:	0 Size:	131.2 KB ID:	52433 Click image for larger version  Name:	20200823_204043.jpg Views:	0 Size:	132.6 KB ID:	52435 Click image for larger version  Name:	20200823_204109.jpg Views:	0 Size:	130.2 KB ID:	52450 Click image for larger version  Name:	20200823_203647.jpg Views:	0 Size:	149.1 KB ID:	52437 Click image for larger version  Name:	20200823_204016.jpg Views:	0 Size:	147.0 KB ID:	52438 Click image for larger version  Name:	20200823_203900.jpg Views:	0 Size:	141.1 KB ID:	52439 Click image for larger version  Name:	20200823_203907.jpg Views:	0 Size:	139.4 KB ID:	52440 Click image for larger version  Name:	20200823_203810.jpg Views:	0 Size:	147.7 KB ID:	52441 Click image for larger version  Name:	20200823_203631.jpg Views:	0 Size:	164.2 KB ID:	52442 Click image for larger version  Name:	20200823_203810.jpg Views:	0 Size:	147.7 KB ID:	52451 Click image for larger version  Name:	20200823_203821.jpg Views:	0 Size:	151.9 KB ID:	52444 Click image for larger version  Name:	20200823_204646.jpg Views:	0 Size:	151.2 KB ID:	52445 Click image for larger version  Name:	20200823_203806.jpg Views:	0 Size:	165.0 KB ID:	52446 Click image for larger version  Name:	20200823_204651.jpg Views:	0 Size:	184.2 KB ID:	52447 Click image for larger version  Name:	20200823_203930.jpg Views:	0 Size:	123.5 KB ID:	52453
    Caliper sets pending cleaning/testing/inspection. If you are interested in any of these please inquire and I will prioritize getting them ready for sale. Occasionally some of them are missing a small part here/there which I have ordered and am waiting on.
    • Set #2 - 73k miles
    • Set #3 - 37k miles
    • Set #4 - 90k miles - rears only
    Do you have the rears? If so how much?
      Titaniu//M I'm looking for rears only as well. I don't need them cleaned or anything I plan to do a rull restore myself.
        I'm no longer in the business of selling these - this thread is over 2 years old
