Only reason for sale is I got a new job, in another state, where the closest track is 5hrs away, and storage won't be possible.
More pics available. I've done my best to capture all the details. Let me know if you have any questions. BIG 3 done and verifiable by AR Motorsports in Tigard OR. Lots of service records for this car. Clean title in hand.
164,825 miles (9.25.22)
3,107lbs w/ half tank fuel
Can be street legal w/ state reg + insurance
Currently in Portland OR area
INTERIOR
OMP HTE-R Seats (Driver + Pass) (Valid thru 2024)
OMP Lumbar pillow
Schroth Flexi 2x2 6pt Harnesses (Driver + Pass) (Valid thru 2024)
VAC Seat mounts (Driver + Pass)
VAC sub belt mount (Driver + Pass)
VAC slider on driver’s seat (driver’s seat installed...Pass seat included)
Kinematic Solid mount Speed shifter
HARD Door cards
HARD Door pulls
NRG Quick Release Hub (SRK-250CF)
NRG short hub adapter (SRK-E46H)
Sparco R323 steering wheel w/ horn button
S2R Tuning Carbon Fiber Sunroof Delete panel
1/2 Cage installed + Painted by AR Motorsports - 2/20 - 160,825 - AR Motorsports
Bimmerworld Pedal Set
VAC Fire Extinguisher Mount
SPA Technique 5lb FireSense+ fire extinguisher + quick release mount (service due 5/23)
All airbags removed (no light)
All interior lighting removed
ENGINE
SMG to 6MT Conversion - 2/2018 - 151k miles - AR Motorpsorts
Clutch Masters FX100 Clutch + Lightweight Steel Flywheel - 2/2018 - 151k miles - AR Motorpsorts
Valve Cover Gasket + Valve adjustment - Jan 2020 - AR Motorsports
Full Vanos rebuild - Dr Vanos Full Unit, Intake Hub, Intake Gear, Cryo exhaust Hub - 2/20 - 160,825 - AR Motorsports
Valve adjustment - 2/20 - 160,825 - AR Motorsports
Timing Chain tensioner + guide rail - 2/20 - 160,825 - AR Motorsports
Rod bearings serviced (Treated bearings + ARP bolts) - 2/2019 - 156k miles - by AR Motorsports
OEM Starter replaced - 2/21 - 161k miles
Water pump replaced - 6/2021
Thermostat replaced 3/2020
Bosch alternator - 11/2021
Upper + Lower coolant pipes + sensor replaced - 3/2020
New Coolant return line - 2/2021
New dipstick
New dipstick o-ring
Power steering pump + lines + reservoir replaced OEM 6/2021
AFE Intake
Bimmerworld Group B Motor mounts
Belt Tensioners replaced - 2/2021
Drive pulley tensioner - 2/2021
Turner Race Pulley kit (3) + belts 12/2021
Aftermarket section 3 exhaust
Oil changed frequently w/ LiquiMoly 10W60 (will be fresh upon sale)
Rear Diff fluid - 75W140 GL-5 Gear Oil (will be fresh upon sale)
Rear diff - new drain plugs
Trans fluid - D6 ATF (will be fresh upon sale)
Trans - new drain plugs
SUSPENSION
MCS 2-way Non-remote -5/22 @ 164,486
Eibach Springs (650/750)
Ground Control Race camber plates
Ground Control race rear shock mounts
Ground Control rear weight jacks
SPL Front Sway Bar Adjustable Endlinks
Alignment + corner balance 5/22 - AR Motorsports
Rear Subframe reinforced - Bimmerworld kit - 2/2018 - AR Motorsports
Bimmerworld Poly rear subframe bushings
Diffsonline rebuilt rear diff - 2/2018 - AR Motorsports
Powerflex rear diff bushing
Rebuilt LR axle + CV boot - 2/2018 - AR Motorsports
Ground Control rear lower control arms
OEM front control arms - 4/2021
Condor Speed shop Control Arm bushings (centered) - 4/2021
New lug bolts - (will be new upon sale)
LR wheel bearing - new - 5/2022 - AR Motorsports
BRAKES
Hawk DTC-60 Pads F/R (will be brand new @ time of sale)
Castrol React SRF Fluid ((will be brand new @ time of sale)
Zimmerman Rotors (F/R) ((will be brand new @ time of sale)
StopTech SS lines (F/R)
WHEELS
18x9.5 ET28 Apex FL-5 Anthracite Wheels
Metal valve stems
275/35/18 Hankook R-S4 Tires
OTHER
OEM Wiper Blades - (will be brand new @ time of sale)
OEM Charcoal Cabin Filter - (will be brand new @ time of sale)
OPTIONAL - Complete Garmin Catalyst system
All 4 Jackpads - 5/2020
Vinyl roof wrap - 2/20 - PDX Wraps
Removed windshield washer nozzles, piping, reservoir + headlight sprayers
Many more pics on the FB Marketplace ad: https://www.facebook.com/marketplace...3371353708208/
5G46_HOD_MCMD_2021_0514_w-1.jpg IMG_2114.jpg IMG_5596 2.jpg 61898005101__8C436208-C7F2-42E9-A0A2-0E58629FFB3D.jpg
INTERIOR
OMP Lumbar pillow
HARD Door cards
HARD Door pulls
ENGINE
New dipstick
New dipstick o-ring
AFE Intake
SUSPENSION
BRAKES
WHEELS
Metal valve stems
OTHER
