--Sold---2002 M3 Weekend/HPDE
    ---SOLD---The time is come to unfortunately sell a BMW that has been with me for over five years I. I purchased this car with 102,000 miles on it and I’ve slowly transformed it into an HPDE/weekend car. The car does not get much used anymore, due to some damage that took place. I am slowly working this car back to a perfect condition, but some life-changing events have taken place and it would be easier for me to sell and get back into the game in a couple of years when I have more free time.
    I spared no expense when building this car I absolutely loved her to death. The time dedication and research that took place to upgrade each and every piece of this car is something I pride myself over. If you would like to see the work, please head over to my Instagram Jersey_M3 to see the history of the car under my ownership. With every part being carefully curated, there is no doubt in my mind that you can put this car on a race track in 110° day and not have to ever look down at the oil or coolant as it will turn steady lap times. It was built for this purpose. It was over built to not have to worry. It was over built to be reliable.
    Every oil change was done with a Blackstone lab analysis so if you would like data points on the engines health I would be happy to provide.
    Before my ownership, it was owned by a guy in Virginia who did a couple of short modifications to the car. He brought it to a specialist to lower the height of the car and install the KW coil overs. I picked it up in Virginia and begin the transformation.
    On the road this car is docile and tame until you start to push it. As it reaches over 4000 RPM The car will slowly lower itself under aerodynamics and begin to hug every corner. Couple that with a square set up a larger front sway bar and a KW suspension. It is enjoy on the road as you row through the gears with the short shifter
    I have a large number invested into the car and have all of the maintenance records to show it. The maintainer records between the previous owner and myself should be over 25k and it starts in 2012
    20k OBO
    big three all addressed
    Car maintenance history
    M3 - WBSBL93422JR14825
    Purchased at 102,000 miles
    Paint sealant and iron x - 103,000
    Transmission oil change - 104,000
    Motor oil/filter change - 104,000
    Liquid Moly friction modifier - 104,000
    Fuel filter -104,000
    Hardwired radar detector - 104,000
    Hood emblem replacement - 104,300
    Divers side window seal replacement - 104,500
    New master & valet key - 104,500
    Alternator replace - 105,500
    Opti-coat gloss coat - 105,500
    Spark plug change - 105,500
    Compression Test Average is 141.66
    3 tensioner pulley replace - 105,500
    Rear differential fluid change - 105,500
    Ride height raised -106,000
    Chrome grills - 106,250
    Rear diff input seal - 106,500
    Tire rotation counter clockwise - 107,500
    New battery platinum series - 108,000
    Suspension adjustment - 108,500
    56mm front
    11.4 mm rear
    Rebound 7 clicks front
    Rebound 8 clicks rear
    Ride height 13.25 inch all around from
    Center cap
    5" ground clearance
    Sway bar upgrade - 108,500
    17.7mm in from back
    110,000 miles - 10/5/17
    New windshield wipers - 110,000
    Rear and front reinforcement strut plates - 110,000
    High pressure vanos line - 110,600
    Oil change - 110,596
    Ceratec fiction modifier added
    Oil filter change
    Oil sent to blackstone labs
    Magnetic drain plug installed
    Stainless steel brake/clutch lines - 111,000
    Full brake fluid flush
    Brass caliper bushings
    Throttle body cleaning, airbox and idle control valve cleaning - 113,000
    115000 miles 5/20/18
    Vibra-technic motor mount - 115,000
    Pfc z-rated pads 115,000
    Wheels and tires 115,000
    Mischimoto oil cooler upgrade -115,000
    Cooling system refresh - 116,000
    Water pump with metal impeller
    Temp sensor
    Silicone hoses
    Thermometer and all o-rings
    27% percent blend good to +7 degrees
    Tuner Motorsports wheel stud kit -116,000
    OEM strut brace - 117,000
    Oil change - 117,220
    Oil analysis, oil filter change, friction modifier added
    Camber plates added - 118,100
    Brake ducting added - 118,000
    Front duct, backing plates
    Transmission mount added - 118,100
    Vibra technics Mount
    All new bolts on full exhaust -118,00
    Vanos bulletproofing - 118,100
    Turbotoy v3 hub
    ARP Camshaft bolts
    Besians reseals
    Besians upgrades chain guide
    New elring valve cover gasket and gromets
    120,000 miles - 5/5/19
    Full CMP subframe reinforcement Weldon kit 122,000
    Every bearing on rear end refresh
    Solid subframe bushings
    Syncro design works RTAB
    Differential reseal
    Interior floor seat well and trunk stitch welded at seams
    All parts sandblasted and painted with special paint
    Rear control arms weld in reinforcement
    New center support bearing
    Alignment - 120,000
    Rod bearing work all OEbearings -125000
    New motor mounts
    New steering coupling
    Updated aluminum oil return line
    Front subframe reinforced
    Oil and filter change, sent to black stone
    Power steering flush
    New fuel injectors - 125000
    No revs over 4,000 rpm
    Oil change, filter change , fritction modifier added - 126100
    Transmission oil, differential oil, brake bleed, brake ducts added, air filter cleaned, MAS cleaned, valve adjustment - 129,000
    Alignment and comer balance for 160 lb driver - 129000
    130,000 5/28/21
    Oil change, filter change , fritction modifier added - 131410
    Oil change, filter change 132081
    Fcab, all new power steering parts, power steering pressure reduction, windsheild washer replace and rewire -133,000
    Oil change, filter change, coolant changed (50/50+water wetter), brakes flushed - 133,500
    Car spare parts
    OEM engine sound damper
    CMP Auto Engineering 6 point race brace
    OEM front bumper support
    OEM Strut brace covers
    OEM Transmission brace
    OEM EURO headers
    OEM suspension
    OEM puller fan
    OEM Side skirts
    KW suspension adjustment tools
    SCROTH racing 4 point harness
    OEM sway bar
    OEM oil cooler
    OEM Air shroud
    Aftermarket side markers and grills
    OEM steering Rack
    OEM power Steering Pump
    OEM Fuel Pump
    OEM Water cooler
    OEM expansion tank and hoses
    OEM power steering pump
    OEM power Steering lines
    OEM Center dash
    Apex 18x9 wheel with Federal Rs-RR. 255-35-18
    OEM front wheels and Tires
    3 sets of brake pads. OEM, PFC 08, PFC 06
    Dr Color chip paint repair kit
    OEM illuminated shift knob
    Enough oil for almost 2 oil changes
    Oil for transmission flush
    Oil for differential flush
    Coolant concentrate
    OEM Steering coupler
    OEM Front bumper license support
    So many OEM nuts and bolts that I don’t care to list. I basically tried to double order and Nut or bolt I replaced on the car, ended up with lots of spares
    Tuner motorsports 7.5 mm spacers (2)
    Valve adjustment shims
    Valve adjustment tool
    OEM Vanos gasket
    OEM shifter
    OEM muffler
    Aftermarket wheel stud kit​
