The Rogue Engineering DSSR (Dual Shear Selector Rod) has arrived!
The major problem with the DSSR design is actually installing it through the selector rod gear joint and/or the bottom of the shifter lever. This is especially true of required plastic washers or other shims are required. So, you have a tight space, the challenge of a washer, shifter lever pivot, another washer...ensuring they all line up through the M10 hole of a DSSR, to finally put the pin through. Cursing and tool throwing is allowed (even expected). Patience is definitely helpful.
The Rogue Engineering DSSR design resolves this installation dilemma. Since our DSSR is designed as two halves (or end-cap version), all the required pieces can be installed onto each side independently. Once completely installed, the two halves are ingenuously indexed to line up and be secured with easy-to-access hardware.
Product Details:
The Rogue Engineering Dual Shear Selector Rod may be viewed at the following link to our online store:
https://ind-distribution.com/products/rogue-engineering-dual-shear-selector-rod
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | [email protected]
Product Details:
- Fully CNC’d 6061-T6 ACQ aluminum construction, anodized for corrosion protection
- NO circlips used in our design!
- Easy installation (compared to conventional DSSR designs)
- Grade 12.9 hardware included
- Adjustable tension! When the shifter starts to develop “play” you can tighten it up with a simple Allen key!
- Compatible with other branded shift kits (if a factory selector rod is used)
