weight info for parts...?
  • AlexGTT
    Originally posted by northernjim View Post
    You got that one right Alex :beer:
    He's one sad fekker that shimmmmymacher :hahaha:
    Pot kettle he might say!
    Your even worse Jim.:-D
  • shimmy
    TEAPot kettle he might say!
    EFA:blalalala:
  • northernjim
    EFA
  • AlexGTT
    it all adds up. means very little when you are having fun, but if really trying to get the times down (which some sad-oos like Shimmy do) 50kg makes a diffenrence to power to weight, tyre life/grip, braking
    EFA
  • shimmy
    Originally posted by toplad View Post
    Just say you save 50Kg of weight, is it really going to make any difference in the real world, I know it does in theory.
    Isn't just a massive waste of time and money to save what would probably be a 0.5 second, and only then if driven at 100% of the potential performance?
    it all adds up. means very little when you are having fun, but if really trying to get the times down (which some sad-oos do) 50kg makes a diffenrence to power to weight, tyre life/grip, braking
  • toplad
    I would expect lighter wheels and better rubber to make the most difference
  • ChrisCSL
    Originally posted by TANKSLAPPER View Post
    Not a lot, as the boot skin is carbon and the bonnet Alloy.
    Remove air con & Xenon is easier.
    T$
    How much can save bulbs compared to Xenons ?
  • Kislik
    SO I have SS back box and battery and now suspension and recaros go in, cage goes in and rear seats go out. I'm curious the difference maybe I should let garage weight it before and after so we see some real data.
    btw I also lost 10kg on driver weight reduction which I got for free :hahaha:
  • azrael
    Also you would want to try and keep the near 50:50 weight distribution.
    How weight you reckon needs to go to match the GT3 or GT3RS power to weight ratio? Only 10kg between the cars it seems. Obviously harnesses help and Aero
  • Rutkowski
    Wheels, lighter seats and BBK - that'd be all for me. I think too much weight taken off would upset the car's balance....
  • NZ_M3
    Actually the factory boot lid is all FRP and it's freaking heavy - I have one in the closet and I can tell you that it was surprisingly heavy when I picked it up. You'd easily shave at least half the weight off one by going full single skin carbon fibre with no internal support structure. Just don't mount any spoilers on it instead mount it to the rear chassis rails
  • AlexGTT
    Originally posted by Kislik View Post
    just feeling that monoblock is better than 2 piece
    It is, and if you were building a racecar fine. But you honestly won't need more than AP's with the right pad/disk combination for a TD car and especially at Ring.
  • Kislik
    Why? Most find AP's more than enough on a CSL. They won't fade for sure.
  • AlexGTT
    as a real lightweight i race with Radical SR4, so I sure this will always be much heavier, just looking what all I can do without loosing the CSL soul :-)
    - big brakes but no love for the 2 piece AP, more Movits or Brembo monoblocks
  • AlexGTT
    Originally posted by Curly View Post
    No washer fluid and run with less fuel
    But how would you pull the old "I had to wash my windscreen" trick John?:clown:
