To Supersprint Header or not?
  • alexk
    Originally posted by The Gorilla View Post
    Its also why back in the days of the 'real' DTM
    era, 4 pots started running 8 injectors, as
    the sequential injection with the second bank
    of 4 mounted further up the Intake runner,
    coming in at say 6000 rpm would keep
    the fuel atomization from going to fine
    right when the engine was making peak
    power..
    Regards,
    The Gorilla.
    Gorilla, excellent post !
    Also, this is the case with superbikes like my RSV4 factory, they are running 8 injectors.
  • titan
    Now thats what I call a post, cheers for that found it very useful.
  • northernjim
    you asked Jim :hahaha: now you are FoOKInG confused
    it takes far less than that to lose Jim Gorilia
    C unit!
    Good post G man, but please stop teaching these numb nuts too much- what is it they say..... a little knowledge is a dangerous thing. :hahaha:
    I have already said that:birdman:
    tbh I was talking more about the AFR's, which once the injectors max out when you turn the 'wick'( technical term for you there steve go look it up:birdman up a bit, will surely lean the engine off with a result of more power ( not neccessarily safe long term power I add)
  • shane@mbtech
    Hi,
    NortherJim- This explains the basic paramiters.
    Save me from typing it all out !!
    '''There are a few important factors that you must take into account when modifying an electronic fuel injection engine. These are: the pulse duration of the injectors and the duty cycle.
    The injector pulse duration is the amount of time that the injector is held open so that it can inject fuel into the combustion chamber. The pulse duration is controlled by the engine control unit (ECU) and is dependent on various sensors in the electronic fuel injection (EFI) system. The longer the pulse duration, the more fuel is added to the air/fuel mixture. The amount of fuel required at any one time varies by the amount of air flow, the air density, the engine load, and the engine temperature. Therefore the pulse duration will vary. However, there is only a limited amount of time that the injector can be held open at each revolution of the engine. This amount of time is reduced as engine speed increases. For example, at 600 RPM the available time is 0.1 seconds (60 seconds in a minute divided by 600 revolutions) but at 6,000 RPM it is only 0.01 seconds. The pulse duration relative to the available time at the engine red line is called the duty cycle and is expressed as a percentage. Thus a duty cycle of 80% means that at the engine red line the pulse duration (the amount of time the injector is help open) is 80% of the available time.
    INCREASING THE DUTY CYCLE
    Some engine tuners will tell you that if your car has a duty cycle of 80%, you have a possible gain of 20%. However, the injector is an electronic solenoid and cannot be held open for too long or it will overheat and fail. In practice most Nippon Denso and Rochester injectors will remain reliable at up to an 80% duty cycle; most Bosch injectors will remain reliable at up to an 85% duty cycle; and most Lucas injectors will remain reliable at up to a 92% duty cycle. Though even at these duty cycles it is still advisable to test the injectors. Test them specifically for their spray pattern and their flow volumes at the maximum duty cycle you require.
    On a race engine I wouldn't exceed a maximum duty cycle of 80% as dyno-testing on various have shown that a duty cycle in the region of 60% to 70% produces the best power. This is because a shorter duty cycle does not allow for the proper atomization of the fuel, and proper atomization is important for the proper burning of the air/fuel mixture. I usually aim for a duty cycle at the point where maximum power is reached so as to ensure the longevity and reliability of the injectors. So, how do you adjust the duty cycle? By adjusting the fuel pressure and the injector nozzle size. On an OEM EFI system there are certain limitations on increasing the fuel pressure and the injector nozzle size. I'll discuss increasing the injector size in a while, but you can read more about increasing fuel pressure here.
    INCREASING INJECTOR NOZZLE SIZE
    Increasing the injector nozzle size will result in increased fuel delivery all the time. As "Langer" mentioned in engine basics, a rich fuel mixture results in power loss. Therefore, increasing the nozzle size could have a negative effect on performance and economy. The oxygen Sensor (O2S) will correct the fuel mixture for an injector that is about 20% larger than stock. However, on a pre-1996 EFI system, the ECU will ignore the O2S sensor under full throttle conditions. Furthermore, the OEM ECU will not be able to handle an injector that is more than 20% larger than stock and will suspect that one or more of its sensors are faulty and will revert to its programmed settings, which means that the fuel air mixture will not be optimal and will probably be rich as this is the failsafe setting on the ECU when it suspects that its sensors are faulty.'''''
    Without going into specific Calculations,
    at 85% of their Duty cycle running at
    6 Bar fuel pressure [86 psi] + 1 Bar
    over std, which is very high, then the
    std S54/CSL injectors are capable of a fuel
    poundage which equates to around
    370/380 BHP on a L6 engine.
    Reducing the Injector Duty cycle down to say
    70/75% for a performance Race engine
    High lift Cams, 12.5 CR and so on, would
    equate to around 370 BHP at very best.
    Its why the Fuel Injectors of the F430,
    carried over from the Enzo and used in the 458
    are regarded as one of best as they
    use a a 5 nozzle arrangement giving immense
    spray volume but without really fine atmoization
    which for a high performance engine is
    exactly what you really want.
    power..
    Regards,
    The Gorilla.
  • s.mac
  • The Gorilla
    Hi,
    power..
    Regards,
    The Gorilla.
  • glendog74
    WTF NUMB NUTS
    Stick to your normal posts
    :thumbs::thumbs::thumbs::thumbs::thumbs::thumbs::t humbs:
  • s.mac
    I will have to see how many laps i need to do, to lap you at oulton:birdman:cnut
    :smt044
  • northernjim
    WTF NUMB NUTS
    :hahaha::banghead: thats me put back in my place!!! I will have to see how many laps i need to do, to lap you at oulton:birdman:cnut
    :hahaha::hahaha::thumbs:
    you can pipe down too laughing smiley man:hahaha::blalalala:
  • Bounce
    WTF NUMB NUTS
  • s.mac
    I agree with the inconsistencies in RR data, how tight the straps are and a whole load of other variables can be used to 'influence' shall we say the outcome....
    but re the injectors, what size are they as standard?
    and how lean does a csl run? as if the injectors are maxxed out then you'll just get more power from a the leaner mixture???? ( upto a point?) This may be a case of a little knowledge that can do a lot of harm in the wrong (my) hands:clown:
    can you explain in laymans terms mr Primate please:beer:
    WTF NUMB NUTS
  • northernjim
    Hi,
    The ''Gains' it makes will depend
    on who, how and where, its 'Dyno'd'.
    You only have to look at the recent Lap times
    at Britcar.
    Sureal how many S54s make over 400
    BHP on the std Injectors when the
    Data from the Injectors Duty cycle
    proves its factually impossible.
    But hey, what the fuck do I know.
    Regards,
    The Gorilla.
  • glendog74
    Hi,
    at Britcar.
    Regards,
    The Gorilla.
    You know lots Mr Primate
  • The Gorilla
    Hi,
    at Britcar.
    Regards,
    The Gorilla.
  • s.mac
    You may as well skip it... :hahaha:
    that good Rob?
