I was advised not to go for the steel one because they rust?
i dont know :119: + steel stronger than Titan???
Ordered Intrax 1K2 - questions/suggestions
Had problems with the Titanium ones that were fitted in about 2007 ?? and as I track mine, and its caged etc. the steel options are stronger IN THIS APPLICATION, Titanium is only stronger when considering it in a strength/weight ratio. Titanium is also more brittle than good old steel !Originally posted by 83SY View PostWhat made you go for steel??? :banghead:
Collected the car today, running -10F/-15R, with the roads being wet today I found that setup to be a little bit 'spiky', will probably move to -15F/-20R and see from there.
Body control has improved immensely over the PSS10 setup. Though I was hoping the 'ticking' noise on surface imperfections coming from the rear (left and right) would be cured with the new dampers. Is this something affecting all uniball'd cars? (My PSS10 was also equipped with uniball top-mounts) Note that my car is stripped and caged, it might pass more noises on to the driver than a regular car.
Further impressions will follow!
Well currently running Supersports but will be switching to Cups next season.Originally posted by shimmy View PostThere are circuits that ideally require -3.0 or even -3.5 camber to get best grip and also tyre wear more evently. Not sure about the Ring but I guess -2.5 on Cups will probably be fine.
Regarding toe-in/out, any suggestions?
There are circuits that ideally require -3.0 or even -3.5 camber to get best grip and also tyre wear more evently. Not sure about the Ring but I guess -2.5 on Cups will probably be fine.Originally posted by Porker View PostGiven the Intrax will come with camberplates as well, is there a preferred geo setup for fast road/Nordschleife useage in combination with Intrax?
Currently running switched top-mounts front which gives about -2.5deg camber, I was quite happy with this setup. Is there an advantage to be head in increasing front negative camber more still?
Do it:beer:Originally posted by conleth m3 View Postmaybe i'm just a gayer and prefer it softer :gayfight::whistle::whistle::whistle:
mine still for sale though, not actually tried to sell them to be honest. still got the idea of a cheap e46m3 stripped/caged and with all the bits i took of my csl as a trackslag to complement the gt3 :supz:
artyman:
i requested this from henk and got 100/50 springs which i found fantastic. i ran them as shimmy says half way (20/25) for road. i softened them off by 5 clicks for the 'ring though rather than hardened them up from road settlings. just felt better for me over the kerbs/bumps of the nordschleife. but then for smoother circuits like donny/spa would harden them 5-7 clicks from midway both front + rear. suppose only had them on the car for 6 months before i sold the csl so didnt have as much time to play with the settings as othersOriginally posted by Porker View Post
I have specifically requested trackday/ring springs/settings so I'm assuming I will get the 120/60 springs.
Go for the black titan! if nothing else it looks awesome... :supz:
I went to intrax early this year, standard setup to Intrax was a big difference. Adjustment very easy.
If I was doing it again this would be my ideal combo,after having 100/50 and 140/70 for road and track.Originally posted by need4speed View PostINTRAX all round, speak to Henk or Neik in Holland and they will put you right. Ask them about the anti roll control system that they can add on to the 1k2 system had it installed it on the dampers when the suspension was overhauled and set up earlier this year. My own personal dealings with INTRAX and the people involved have been superb.
Current set up 120/60 springs and stainless steel damper bodies fitted with anti-roll control valves.
I've got some 120/60 to try for next year, but otherwise I'm happy. They work fantastically on the e46Originally posted by Porker View PostHi Shimmy,
Thanks for the wealth of info! :notworthy:
Have you been happy with your choice for Intrax? If I'm not mistaken you are the one with the 2'49" Spa-lap? Can't wait to have a go at that, I've refused to go to Spa on my PSS10-suspension, I'm assuming on Intraxes it will be a blast...
They are however race dampers and not maybe as long term reliable as road dampers. I've had mine refurbished. I know some had had fronts seize after a period parked up and a couple of knockings on rears
I would nt change though and mine have covered 50k miles
