CSL Mileage...
  • billyboysm3
    89K with FBMWSH :thumbs: Still running on original engine with original HG :smokin:
    Engine oil & filter changed every 4K miles ... or at least once a year.
    Gareth did a compression & leak down test last year and it was bang on speck & tight as. :supz:
    Good going!!
  • Straightsix
    Mines on 85000
    Head gasket changed at 89000 :hahaha:
    So how does that work ?
  • Straightsix
    Originally posted by Monkey View Post
    I'll post up a photo of a failed S54 headgasket I have at work tomorrow.
    Thanks
    I remember the old BMW M20 6 cylinder engines were notorious for head gaskets
    Stuart Draper's M3 I thought did 170k on the original engine needing NO head gasket work well from what I read in Total BMW's E46 M3 buying guide in 2012 :-)
  • Jon8710
    jim
    dont worry about the sub frame problems, most have been fixed now and if they havent dont buy it, mine has had a relatively easy life with no track action and it still cracked its not if its when !
    regards to head gasgit how long is a peice of string ?
    if you are buying get one with full warrenty you would be mad not to as a small trip to the garage could be more than a year of payments !
    saying that mine has been nothing but a pleasure to own, forget milage go with history and the way the car ia presented.
    you will know if its a stinker !!!
    i allways look at scuffs on the rear seats dont know why but if they are all scuffed up i think its a shed.
  • Big Jim
    I'm on the lookout for a lo wish mileage CSL at the moment and this gasket problem is a worry. Is it something that's been cured on later examples?
    I've also seen reference to floor problems. Does this indicate abuse/track day cars?
  • Monkey
    Originally posted by Straightsix View Post
    Why do the head gaskets go ? How do they fail ?
    On regular M3s is this usually a problem above 100k miles or 50k miles ?
    Presumably M3 CSLs are seeing this at 60k miles plus because they have been driven very hard on track ?
  • DuncanR
    Mines on 85000
  • Straightsix
  • mattCSLnut
  • Yanto
    73k
    Leak down test before Munich...
    Tighter than a..........:supz:
  • sjb
    65k and head gasket being done right now but that should really be the only serious mileage related issue I gather.....
  • Bounce
    81k FBMWSH and pulling like train.:smokin:
  • cslsuperfan
    70K
    70K absolutely fine but SH a must.
    Mine's on 60K awaiting HG failure!!
  • glendog74
    Mine is 78k now.
    HG replaced around 70k.
    Car fine since.
  • martin770
    Mine is at 66k now, the head gasket was done at 63k, But mine is running great.
