No go
  • Bounce
    Nice one mate. Mine passed her MOT last week with only two minor advisories :thumbs:
    Good news mate,let me know when you want to go for a spin :thumbs:
  • glendog74
    New Battery,new all singing all dancing C-tec charger(had the old one 7years)and we're off :thumbs::thumbs:
  • AlexGTT
    Good news Brett. :thumbs:
  • Bounce
    Originally posted by cslsuperfan View Post
    Good excuse for a blast Brett!!
  • cslsuperfan
    Just had a great blast back from Adem, car all sorted ready for this years use :thumbs:
    Craig
    I'm booked for Spa in August 4-5
    Hope to see you there
  • CraigMillwardCroft
  • cslsuperfan
    Ok,started right away when I jump started it,went and got the battery checked and they said it's fine,just needs charging.Now if someone in the know could enlighten me,I thought if a battery was down on power and not able to turn your engine over it was fucked,but he said a good run of 50-60 miles should sort it.Also these C-tech chargers are good but not man enough over a longish period,although this is the first battery issue I've had in over 6 years
  • nw942
    I think it depends on how sulphated the battery is inside. And that depends on how the battery has been used, and more importantly how it has been re-charged, in the past. I think most chargers monitor the voltage and this can give a false indication of the health of the battery.
    Earlier this year my daily failed to start. Put it on the CTek that evening and within two hours it said it was okay. Put it back on the car the next morning and it started. That evening it failed to start.
    Put it back on the charger and when it reported a full charge I measured the voltage at 12.60V. Disconnected the charger and the next morning I checked the voltage again - it was 11.60V. So it dropped without any load on it at all, which indicated to me that it was time to change it.
    I did try the recon program on the CTek, but that didn't help.
    I think for maximum battery life you need to keep it constantly above 80% (around 12.45V) to avoid the sulphation, but that is easier said than done for a various reasons.
  • Pip1968
    I cannot see the C-Tek not being man enough. If it has been fine for 6 years then it should continue to be. Personally I would look at dirty contacts on the C-Tek to battery, a failed C-Tek, something draining the battery on the CSL (tracker/poor earth connection) or the battery is on its way out.
    I think they say that two complete discharges and the battery is kaput.
    Pip
    Mine has been on the charger all its life left for long periods and always starts, when I can remember how, just off for Airbag recall then to Adem for MOT and oil service :thumbs:
  • Bounce
  • Chad
    No worries Chad
    anytime you fancy a run out
    I'm fairly local..... SY15
    evo triangle, LLanberis all within 60 minutes.
    Hi Ben just googled up triangle, be up for a run round, last run out down that way for a buzz, did that zip wire ride snowdonia, hopefully roads not as scary as that f...ing wire. Chad
  • cslsuperfan
    Originally posted by Chad View Post
    Just a bit of banter Ben , stand corrected
    No worries Chad
  • Chad
    No chad
    definitely not extinct not yet anyway
    Brett's been accused of a lot of things but not driving his csl has not cropped up before!!!!
    Been on umpteen register events and track days with the csl.
  • cslsuperfan
    Glad to help Brett, I think we should all drive them more, I have only ever seen one other Csl on the road, starting to think Csl beasts is extinct!
    No chad
