Another Headgasket Bites the dust!
Don't be daft, I love the place - just taking the piss out of ourselves who do go.Originally posted by XKaLiBaR View PostYou dont like the Nerdring? :blalalala:
Be interested to see the state of your HG when it's apart - wonder if you can beat 5 cyls all joined up :hahaha:
Has Hazy hijacked your account Shim:hahaha:Originally posted by shimmy View Posti tend to drive in hot, no cool down and jump out into the aircon race truck asap
makes me feel much better :thumbs:
Originally posted by NZ_M3 View PostI agree completely ... cool down laps are a must (although I gather harder to do at the ring), if you can't do the cool down laps, at least let it idle with the bonnet up after the hard laps.
And ALWAYS let the thing warm up gradually.
I try to put my heaters on full heat with the windows down to get a bit of heat out the engine on my cool down lap, works a treat and the oil temp drops down far quicker too. Gets you a bit hot though
I agree completely ... cool down laps are a must (although I gather harder to do at the ring), if you can't do the cool down laps, at least let it idle with the bonnet up after the hard laps.Originally posted by thegingerninja View PostIt is very important to let an engine warm up gently and allow the different metals to heatsoak during warm up - but just as important is to allow them to cool down. If you do a lap of the Nerdring on a baking hot day and drive flat out all the way to the gantry with your aircon on full and then park it up, you will probably shorten the life of your head gasket (amoungst other things).
Isnt the long straight after the gantry enough to let the car cool down? I do agree with you, as i see so many people pull into a pit lane after hot laps, and just park up.
I doubt the piston would have hit the spark plug - it is probably detonation on the crown of the piston (which can look like physical contact, but only to the untrained eye - which should make you even more concerned about the people taking your engine apart!)Originally posted by bromers View PostFeel for you mate.
I've still got 'people' looking at mine - could be a new engine, they think the piston has hit spark plug so not technically a head gasket failure but maybe a HG failure could of caused it ?
Mine's on 28k and has been used mainly as a commuter.
9 weeks and counting and still no remedy.
There definately seems something with age/mileage causing this to happen. Does the standard M3 suffer from the same ?
If the coolant isn't changed on time you can get an accelerated rate of corrosion around the block (as it is cast iron) which can weaken the clamping pressure on the gasket between the cylinders. I'm not entirely convinced that just hot running alone can shorten the life of a head gasket - it is more to do with the rate of change of temperature, not the extremes of temperature. It is very important to let an engine warm up gently and allow the different metals to heatsoak during warm up - but just as important is to allow them to cool down. If you do a lap of the Nerdring on a baking hot day and drive flat out all the way to the gantry with your aircon on full and then park it up, you will probably shorten the life of your head gasket (amoungst other things).
I can vouch for that too :blalalala::whistle:Originally posted by shimmy View Post
I think you've got another 20k miles of driving yours half throttle around the Ring before you'll need a new HG Matt
? Do you get Mick to do it then or something?:whistle:Originally posted by lawsy View PostAny routine maintenance will prevent engine issues Yes.
I change my oil after every track day.
I have done 4k in my CSL and oil changed by me 5 times and murketts have just done it last month FOC. It certainly does no harm and the oil temps the cars see when driven hard I think its needed.
That said its very easy for me to change the oil:thumbs:
