Airbox Flap does not open
  • glendog74
    Remove the flap - Simples! :smokin:
  • sailorbaz
    I had this issue once before also and it turned out to be the potentiometer. Straight forward replacement... under warranty I may add, :-D
  • GTR
    Originally posted by giraffe View Post
    Replace the potentiometer common failure .
    Hope this helps .
    Mines got a similar issue, but intermittent. It's at your work place now waiting for you to look at when your feeling better.:thumbs:
  • Bounce
    Originally posted by ChrisCSL
    Hi!
    I just realized that the Airbox lid does not open on my car.
    i revved the car in stood still with sport-button activated like in this vid:
    But the lid did not move.
    I then extracted the actuator and tested it with external power supply. The actuator works. Then opened and closed the lid manually while measuring the resistance of the throttle valve switch. Resistance changed through the turn. So I think both parts are ok.
    I realized, that, when turning on ignition the extracted actuator turns about 3 full circles, then stops. When built in, the actuator tries to turn, but it can't, because it tries to turn via the close-direction, but the lid is closed already.
    Anybody has a clue where the error in the system hides?
    What can I check next, to make the lid operate?
    Chris
    Seem to remember ages ago someone saying,that there air box flap was taken off and when replaced it was put back on in the closed position,when it should have been put back on in the open position,then would not work,if that makes any sense:119:Perhaps yours has been removed and put back wrongly.I may be talking bollox as usual.:-D
  • giraffe
    Hope this helps .
  • ChrisCSL
    started a topic Airbox Flap does not open
    Hi!
    Chris
