Comp or leak down test?
  • AlexGTT
    Originally posted by Chrisc View Post
    Umm one thing i noticed. When i changed the air filter, the insides of the air box well the trumpet looking things were covered in oil residue. I thought nothing of it, as never seen inside a plenum before. Not sure if it was using oil, as not had it long enough.
    Lower down you may remember by remap post, as below 3k was just non existent, again i thought it was a CSL thing with the different cam settings. But seems not after looking into it.
    May have something to do with it?
    And slight mayo on the oil filler cap, but not major at all, like a film. But though it could have been used for short journeys before i had got it.
    Chris, you won't get mayo to great extent because they don't leak into water system, just between cylinders.
    Also, common to have quite a dirty oil vapour residue in the airbox so that's quite normal unless its swimming in oil.
  • Chrisc
    I have no idea what it is but I wish you all the best!
    Cheers mate. To be fair i just want a CSL, and not the wifes 118d
  • shimmy
  • Chrisc
  • AlexGTT
    I'm with Lawsy and Monkey on this. I'd seriously doubt rings. If the compression was as low as that past the rings you'd be getting serious amounts of burning oil smoke out the exhaust and serious loss of performance. On throttle the crankcase pressure would be dumping loads of oil vapour into the intake and on a trailing throttle it'll be pumping up past the rings.
    Leak down test but make sure ALL oil put in cylinders is out before hand.
    I'll lay good money on H/G gone between all cylinders.
  • Chrisc
    You cant diagnose rings and discount HG from a comp test alone.
    A leakdown test is required.
    And then a stripdown before any assumptions are made.
    Well he has the car for his tech to look at, but so far everyone I have talked to have said rings with what has been done. Will see what his guy comes back with.
  • shane@mbtech
  • Chrisc
    Originally posted by billyboysm3
    I dont think I am ever getting my car back, put back another 2-3 months, new courtesy car tomorrow + sweetener.
    :smt087
    At least when you do it will be like a new car! Well unless it turns up with a 320d lump in it :hahaha:
  • Chrisc
    Originally posted by Monkey View Post
    Just for peace of mind I would get the cylinder leakage test done. It's worth it for the hours labour.
    They are doing another test tomorrow, so will see what they find. 3rd time lucky maybe :hahaha:
  • Monkey
    Thats one reason i did not want to go any further. If the head was taken off, i would be into a lot more labour time, plus as it does look like rings, then there is not many options. I have bought all the parts myself to get it done asap (head gasket, bolts, vanos seal, clips etc etc) so already £400 ish out of pocket, let alone anything else. Main priority is having a car! I would of paid and got the money back or whatever later, not worried. But now i dont know what else may be damaged or needing replacing etc, so taking a step back. Just have to wait unfortunately.
    Still would like to know why they have failed, as never seen it before.
  • Chrisc
    Yes you have 2 compression rings and the oil scraper ring. Either way the head will have to come off, you'll soon see if the HG is doomed! At least it's Nick's problem so to speak, and not yours. Keep us updated with the progress, be interested to see how this one pans out.
  • Monkey
    I think he just knew, plus he said when putting a tiny bit of oil in it "clicked" or made some sort of noise, and was the same on each one. Think he said clicked, but a sound that was indicating rings as well. Iirc they are 3 rings in one, but cant remember what else he said :whistle:
  • Chrisc
    I'm sure your guy knows what he's doing For me personally though I would only diagnose an engine issue of this sort with a cylinder leakage test. It takes an hour at most, and is conclusive. I would want to be able to tell the customer for sure where the leakage is, and prove it if they wanted to see it.
    We all have our own ways, we're a weird old bunch us techs!
  • Monkey
    Surely putting oil on the crown of the piston, and then getting 60psi on one crank and 160 on the second. Plus no seepage the other side (test cyl 1 and into cyl 2 for example) would mean its not bridging. And all cyls the same pretty much. Not sure why the oil would not seap out or blow through, especially at 160-180 psi.
    Tell me if im wrong, as want to be 100%
  • Chrisc
    Also just say it is rings, what could cause this? As its running lean, so is that a sign of rings or something like a blocked fuel filter?
    They have so many safety features its hard to think of how it could of happened. Its obviously been like it for quite some time :banghead:
