DIY: Z3 Non-M gauge cluster to Z3M S54 Conversion
Apparently, the 2001 model doesn't have any coding for the lighting. So I have to modify the wiring and install a new relay.
Originally posted by AnthoZ3 View PostHi JBanzhaf, Thank you for your message. With what tools (diagnostic case) can I see this?
Originally posted by AnthoZ3 View PostHello everyone, this is a very interesting topic. I just bought a 2001 S54 Z3 M. Since I couldn't find one in France, I bought it in Canada. I just received it, and to get it approved, I need to modify the lighting, because currently, as soon as the engine is running, the low beams and parking lights (sidelights) work. Canadian standards apply. I've contacted three or four dealerships, and they can't help me. I can't believe it!
I've read several messages talking about coding, but these messages weren't specific to my model. Do you have any ideas? Thanks in advance.
I’m really not sure on the specifics of what’s required for you to get it approved. A good start is to see what coding options are available in NCS Expert, for the general module. That should have what you’re looking for.
Originally posted by Steezyz3 View PostHey, I was hoping you could send me the EPROM file for a z3 to z3m conversion, I've just recently swapped a S54 into my Z3 and need to get the gague cluster to have the right range response. I've already read and saved the EPROM file that was stored. If you can help with the coding plug too the mileage that was pulled from the car was 107305 but any help you can give would be great.
Thanks
-Steve
Thanks
-Steve
Originally posted by burhan View Post
i tried with the dump but it is showing code eep2. also the guage is not working at all. what to do now. appreciate your help.
Originally posted by JBanzhaf View PostBurhan, I just sent you an EEPROM dump from a US spec E36 M3 cluster. It should match the odometer mileage on your coding plug. So it should not have a tamper dot illuminated. Hopefully this works for you.
Thanks,
Joel
Thanks,
Joel
Thanks,
Joel
thank you for response, please if you can try to send me us spec m3 cluster epprom dumps. atleast my half job will be done.
sorry for late response, yes you are right the main eeprom data has been lost with wrong reading. i am using dsp3+ programmer and the cluster for e36 m3. so i need your help to send me dump for both eeprom so i can flash it.
Sorry I'm only replying to you now. I didn't see the post until now. I just sent you a PM asking you some additional details. I should be able to help you get it fixed. I just need to know exactly what you have, and what you're trying to do. The one dump you attached looks like a good dump of the coding plug M93S46 EEPROM, with a good and non-corrupt mileage. I'm not sure what the other dump is, as it does not match the format of the CAN bus Z3 cluster's ST93CS56 dumps, and the non-CAN bus E36 clusters don't use ST93CS56 EEPROMs. It would also be helpful if you attached photos of the chips and the IC that you're trying to flash, to help identify what you're working with. I think you may be possibly trying to flash your internal EEPROM with the wrong settings.
Thanks,
Joel
