Sid's 2003.5 Silver Grey Speed Run
    Originally posted by S14 View Post
    Looking great Sid! What Inconel bolts are you using in your exhaust?
    Also, my car is silvergrey and cinnamon, it's a really cool color combo.
    I am using the OE section 1 to headers bolts.
    And thanks, I love the combo! Part of me doesn't even want to have the windows tinted so that I can keep the fishbowl look and see the cinnamon from outside.
    MCS - Vorshlag Plates - SSv1- SS Dual 2.5" Sec.2 - SS (Hamann) Street Sec.3 - 3.91 Gears - BBS E88s - 996 Brembo - PSMax - SDW Monoball - VinceBar - DMG - Haimus CSL - Karbonius - HTE Tuning - AEM 50-1200
      Malloy 's car had me convinced I needed E88s....
        Yes, I can't wait to see gold on your SGM! I considered gold but went with silver - it just works for my car.
        2005 M3 - SGM, 6MT, Impuls Cloth, Slicktop
        2022 M3 - BRG, Tartufo, xDrive​
          I actually had my friend edit one of your pictures to visualize what my car would look like with gold E88s.
          Click image for larger version  Name:	received_1450734975305873.jpeg Views:	0 Size:	139.6 KB ID:	127780
            Haven't had all that much time to work on the car since school started up again but I did replace the windshield cowl and hood vent.
            Click image for larger version  Name:	IMG_20210924_184205.jpg Views:	50 Size:	60.4 KB ID:	128531
              Swapped out my Dinan muffler for a SuperSprint Street. The Dinan started to drone with my setup and I absolutely hated it.
                Finally.....
                Need to play around with the height of the car a bit.
                  I'm having my E88's built as we speak but damn I'm digging the gold.
                  2005 BMW ///M3
                    What specs are you building yours to?
                    And thanks! Wasn't 100% sure about gold but once they were on the car I was glad I went with them.
                      18x10 ET38 with 1 inch lips and 9 inch barrels.
                      Gonna be stock aka polished lips with an undecided center color. Probably some shade of gray.
                      My car is CB so I don't think gold will look the part.
                      2005 BMW ///M3
                        I have always been a huge fan of the race pocket E88s over the standard center cap versions; my only gripe was that the race pocket E88s had no provisions for center caps. I have seen some pictures of people running caps on race pocket E88s on Instagram but could never find the adaptors online, so I decided to make my own.
                        Credit: @danny332m
                        Click image for larger version  Name:	Screenshot_20211027-233246.jpg Views:	0 Size:	72.7 KB ID:	134934
                        Used Solidworks to design a 72mm to 80mm BBS cap adaptor. The groove on the outside will house an O-ring as a source of friction between the wheel bore and adaptor to hold it in. Will 3D print them soon to test.
                        Click image for larger version  Name:	image_29124.png Views:	4 Size:	360.6 KB ID:	134935
                        These should just slot into the adaptor.
                        Click image for larger version  Name:	image_29125.jpg Views:	3 Size:	81.5 KB ID:	134936
                          I have race faces, if these work for you, would you consider selling me a set?
                          2005 BMW ///M3
                            If it ends up working then definitely.
                              Got the height dialed in and installed a 5mm spacer on the rear.
                              Click image for larger version  Name:	IMG_20211106_113415.jpg Views:	0 Size:	151.3 KB ID:	136153
                              Also thanks jbfrancis3 for the EGT block off. If anyone has an EGT block off installed on their SS section 1, I highly suggest you throw some Loctite on it.
                              Click image for larger version  Name:	IMG_20211105_165345.jpg Views:	0 Size:	60.8 KB ID:	136152
                                Nice build so far! I like whats going on in here..
                                Instagram: @_Frank_Stone_
