Sid's 2003.5 Silver Grey Speed Run
  • Sharocks
    I have race faces, if these work for you, would you consider selling me a set?
  • Sid_E46
    I have always been a huge fan of the race pocket E88s over the standard center cap versions; my only gripe was that the race pocket E88s had no provisions for center caps. I have seen some pictures of people running caps on race pocket E88s on Instagram but could never find the adaptors online, so I decided to make my own.
    Credit: @danny332m
    Click image for larger version  Name:	Screenshot_20211027-233246.jpg Views:	0 Size:	72.7 KB ID:	134934
    Used Solidworks to design a 72mm to 80mm BBS cap adaptor. The groove on the outside will house an O-ring as a source of friction between the wheel bore and adaptor to hold it in. Will 3D print them soon to test.
    Click image for larger version  Name:	image_29124.png Views:	4 Size:	360.6 KB ID:	134935
    These should just slot into the adaptor.
    Click image for larger version  Name:	image_29125.jpg Views:	3 Size:	81.5 KB ID:	134936
  • Sharocks
    What specs are you building yours to?
    And thanks! Wasn't 100% sure about gold but once they were on the car I was glad I went with them.
    18x10 ET38 with 1 inch lips and 9 inch barrels.
    Gonna be stock aka polished lips with an undecided center color. Probably some shade of gray.
    My car is CB so I don't think gold will look the part.
  • Sid_E46
    I'm having my E88's built as we speak but damn I'm digging the gold.
  • Sharocks
  • Sid_E46
    Finally.....
    Need to play around with the height of the car a bit.
  • Sid_E46
    Swapped out my Dinan muffler for a SuperSprint Street. The Dinan started to drone with my setup and I absolutely hated it.
  • Sid_E46
    Haven't had all that much time to work on the car since school started up again but I did replace the windshield cowl and hood vent.
    Click image for larger version  Name:	IMG_20210924_184205.jpg Views:	50 Size:	60.4 KB ID:	128531
  • Sid_E46
    Originally posted by Malloy View Post
    Yes, I can't wait to see gold on your SGM! I considered gold but went with silver - it just works for my car.
    I actually had my friend edit one of your pictures to visualize what my car would look like with gold E88s.
    Click image for larger version  Name:	received_1450734975305873.jpeg Views:	0 Size:	139.6 KB ID:	127780
  • Malloy
    Malloy 's car had me convinced I needed E88s....
  • Sid_E46
  • Sid_E46
    Originally posted by S14 View Post
    Looking great Sid! What Inconel bolts are you using in your exhaust?
    Also, my car is silvergrey and cinnamon, it's a really cool color combo.
    I am using the OE section 1 to headers bolts.
    And thanks, I love the combo! Part of me doesn't even want to have the windows tinted so that I can keep the fishbowl look and see the cinnamon from outside.
  • Sid_E46
    Originally posted by frenzy757 View Post
    Do you know if the kilmats are lighter than the oem sound deadening?
    I am not sure if it is lighter than stock but it is absolutely lighter than the Dynamat I was previously using.
  • frenzy757
    Removed all the brittle OE sound deadening and replaced it with some kilmat.
  • S14
