Knocked out some more maintenance and squeezed in a mod or two. Forgot to take pictures of some work.
As mentioned I completed the following:
- ACL rod bearings with OEM rod bolts and new gaskets.
- New engine and transmission mounts.
- All new pulleys and replaced both belts.
- Thermostat, aux fan switch and auxiliary fan.
- Brembo big brakes front and rear, new rotors, pads and lines.
- Personalized plate.
- Brand new Michelin P4S all around.
- Stud conversion.
- Dinan carpets since OEM is discontinued and I don't want to wear them out.
Next year plans - continue to go over the car and replace worn out parts.
I'm going to also rebuilt my wheels, I have to run a spacer up front to clear the caliper and the offset has become a little too low and aggressive, which in turn forces me to run more negative camber than I'd like. I'll widen the rear lips, and shorten the front lips with a larger barrel.
It never ends!
