Vegas 2006 Imola 6MT Coupe Refresh
  • WOLFN8TR
    Nice work! 🤙
    Not sure if you know about these Hi-Temp O-ring kits or not. The kit also includes Viton O-rings for the 3 heater hoses. Link is in my SIG....
  • 8000RPM
    I’m replacing the three heater core hoses preventatively. Just not something I want to wait around till they fail. Coolant flush while I’m at it.
    I wanted to clean up the throttle bodies, replace the air tube seals, service the injectors and replace the rear cam sensor preventatively since the throttle bodies would be off. Super simple with the TBs removed.
    Click image for larger version  Name:	58B69970-8766-4ED8-9CAC-32DF45EC31B6.jpeg Views:	0 Size:	191.6 KB ID:	69001
    Click image for larger version  Name:	359D52F7-9EE2-4208-9AAD-335E8C8E4124.jpeg Views:	0 Size:	256.8 KB ID:	69005
    Click image for larger version  Name:	CF2A52B8-ED5C-438F-A84D-ADA96F0D3503.jpeg Views:	0 Size:	152.8 KB ID:	69002
    Click image for larger version  Name:	76091CB7-49BC-4E2F-9D4F-F8784066834B.jpeg Views:	0 Size:	184.7 KB ID:	69003
    Click image for larger version  Name:	7F0DCEF0-C53A-4530-98BE-8DC4C1A8CF7D.jpeg Views:	0 Size:	258.4 KB ID:	69004
  • 8000RPM
    Small update. It was time to replace the blower motor. The squeaking got unbearable. I bought an OE replacement but the design was revised from the original. The new unit wouldn’t fit into the old style bracket.
    Old
    Click image for larger version  Name:	A55E9F05-CC6B-4131-876A-DAED4ED8CB0F.jpeg Views:	0 Size:	112.3 KB ID:	66111
    Behr OE
    Click image for larger version  Name:	49C884A2-047F-484C-834D-D77770B707DA.jpeg Views:	0 Size:	196.1 KB ID:	66112
    I ended up having to return the OE and go with the BMW brand as it included the new bracket needed. In case anyone was wondering, Bosch still makes the OE for BMW and doesn’t seem to be available as a standalone brand.
    Click image for larger version  Name:	4F057A5A-8685-444F-983A-F68668F6B2FD.jpeg Views:	0 Size:	87.8 KB ID:	66109
    Click image for larger version  Name:	7854FE2D-D201-4DBA-9452-214058380C53.jpeg Views:	0 Size:	128.5 KB ID:	66108
  • imolared
    Amazing job - Kudos!
  • slavik1988
    🍻 Cheers to you! It is like a completely different car from where you started.
  • 8000RPM
    I love new OE parts. Way to go. Sometimes I wish my car were back to original so I could so this stuff all over again, so rewarding!
    Thank you! It’s definitely been fun and rewarding. It’s hard to not get caught up in the weeds of replacing everything. I’m trying to pick a place to stop but there always seems to be one more thing to do!
  • Tbonem3
  • 8000RPM
    More odds and ends I needed to clean up. Mostly inexpensive and easy things to fix.
    The trim in the trunk was banged up and broken.
    New part so nice and clean
    My sill plate cracked when I removed it to install a new door seal. Replaced it and the clips.
    Cup holders were past tired
    Center trim surround was worm
    Driver’s side window switch was worn out and worn smooth
    Worn shiny on the left and new on the right
  • timmo
    Geez I'm surprised you didn't have any water or condensation issues with what was basically a completely useless vapour barrier!
  • 8000RPM
    Knocking out a project that was on the back burner for a bit. When I got the car I noticed the driver side door glass was not BMW and the window went up slow-ish. Nothing on carfax. There was a nice gash on the trim where it appears the glass didn’t drop and when the door was slammed closed, it shattering the glass...maybe.
    I will be replacing the door glass to BMW, the regulator with BMW since the OE isn’t available and the foam vapor barrier since the original was trashed (probably from the shop replacing the glass the first time).
    Lazy installer mangled the foam, will be replacing this
    Removing the old glass first
    Old regulator out
    New regulator going in
    I ordered the glass online and came well packed. The glass was pretty cheap otherwise I would have left it.
    Cleaned up the old butyl tape
    Install the new foam
    Done!
  • cbean
    Yass, big fan of your restoring as well. How is the PARECL clean up doing? I am looking to do this job soon, I figured your VEGAS heat is a good test on products and process.
    I am thinking of refreshing my MAF as well! Have no idea its condintion other than the car runs... I am betting its OEM @ 80K
  • 8000RPM
    MAF swap couldn’t hurt. The previous one was unknown age but when I removed it, it wasn’t branded BMW, just Bosch. Are there dates?
    Click image for larger version  Name:	D0A4C198-9ADB-40A0-8CE0-973F4DD64D56.jpeg Views:	0 Size:	68.1 KB ID:	58829
    New one
    Old one
  • 8000RPM
    Replaced the clutch bushings with UUC.
  • Bimmerchop
    Nice work, love how you "demodded" it, the old wrap and trunk aren't great.
    Agreed, great journal here. Big fan of how you're restoring this car back, nicely done OP!
  • 8000RPM
    I originally used it 5 years ago on my old M. This time around it was much harder to find. Here is the seller I used.
    This dye is permanent and does not wash out. You can hold a towel in one hand while spraying into your hand then continue onto the project. Use painters’ tape, plastic, or cardboard to protect surfaces from the unwanted dye.
    Question about the fabric dye, I've heard of a couple people recommending the one from simply spray, where did you buy it?
