332k Mile ZHP "Zip" 11/8 How did this car run? M54 Manifold "Rebuilt", General Update
    I don't have a goofy name for it yet.
    However, another E46 I dug out of my friends backyard. Same place I got the Cockroach from.
    This a 2004 ZHP Auto with the Alcantara Interior and fold down rear seats. It has done 331k miles and this will be a car my wife and I do together.
    She has been wanting a E46, this is probably not the best one to start with. However it's still kickin and like all the other cars I have dumped large amounts of money and time into it would be a great parts car. However I would like to see it live some more.
    Before my friend got it, it was driven by a high school student until the coolant light came on before he went to school. He parked it and sold it to my friend Alejandro. Alejandro bought it for the wheels for his S54 swapped wagon, fixed the coolant pipes and it sat around. He also nabbed the headlights. As he was going to resell. I did a compression test and drove it around. Seemed like the bones were here for something, so we agreed on a price and now took it home. It did 90 the whole way home without any hiccups for that 50 miles. It doesn't like WOT but seems peppy and fairly torquey.
    Zee haych pee by Sam DaJam, on Flickr
    The Alcantara Interior has survived incredibly well considering. The steering wheel is fucked, but the seats only has some wear on drivers side bolster. It's a texas car so they have some fade. I will take better pictures to establish as a baseline now that we have given it a much needed general cleaning. However you can see the seatbelt and carpet heel pad have show their mileage but the pedal pads don't.
    I had a decent alcantara wheel and a decent leather wheel but sold them after getting my Nardi on our honeymoon. All that I have left was the original wheel from my M3 which was miles better than the Alcantara wheel that was in here so it is in here as a placeholder.
    Just to get it home, the DISA valve was making an absolute racket. So I swapped it with a used one he had. The pin didn't look it was going to fall out but the unit itself had massive amounts of play.
    So swapped that out in like 26 degrees.
    Immediate to dos:
    Ambient temp sensor ripped out (classic), so source the plug, sensor and see if ZHP undertrays are specific
    Xenon headlights were removed for shit LED(?) converted Halogens. So I need to find Xenons or find OE Halogens and code the LCM.
    Horn is fucked
    Coils and new plugs
    General Fluid flushes and see if a ZF or GM trans. If ZF do the pressure regulator
    The suspension is also as worn out as you can imagine, but it's incredible how composed it still is once you trust it.
    Someone gave me a free E46 330i 6 speed many moons ago. That I got to be a reliable daily driver, however with the 2.93 and stock throttle mapping. It was so dull to drive. I always chose to drive my E28 instead, unless I was taking people out. I never really fell in love with it but I have been through all the M54 horrors before.
    Untitled by Kurvenkamph Motorsport, on Flickr
    Bumper by Kurvenkamph Motorsport, on Flickr
    This ZHP even with the auto seems much peppier and calibrated very well. I had similar thoughts driving a manual one over a regular 330.
    But anyways yea that is the introduction. Here we go.
    Build Thread:
    You should call this one Dung Beetle.
    LOL
    2005 BMW ///M3
    Black6MT Daily
      Went to the yard to get the ambient temp sensor stuff and see if I could cobble in some fender liners. I had my old undertray from my 330i. So I cobbled it all in, but even the brake duct brackets were brackets are missing. How does everything get ripped out, cut off and even those removed? It's just impressive.
      I also saw this while doing that fun.
      Both horns are fucked, fixed the wiring and getting voltage to connector, hearing relay. Somehow both are dead pretty incredible.
      Trying to get it to pass inspection before dropping some dough on it, so hopefully CEL stays off and readiness passes. We only have to pass emissions here now.
      Needs to pass to put it in our name, and once that is done can start shoveling money at it.
      Build Thread:
        Price out those ZHP brake ducts...
        What are your faults?
        Email to [email protected]
          0! If I don't floor it!
          Passed! Can start with title paperwork and than throw parts cannon at it
          Build Thread:
            Drove it to work, and than on way home saw almost all the needed monitors were ready. So went on the highway as soon as they showed as ready pulled into a State Inspection station.
            Build Thread:
              330i is the most E46 of all E46es.
              2003.5 SG/Grey
                Window reg fixed, better armrest in and window switch replaced. Title stuff is getting sorted before large FCPEuro order
                However, fuck Xenon. Bought some parts for the parts cannon. Hopefully can update on that soon.
                Build Thread:
                  ZHPs had Xenon headlights made by ZKW, known issue with the reflector bowls burning which makes the light output essentially 0. Retrofit aftermarket Xenon/HIDs into the housings or get a set of AL's.
                    Yes my 330i had that issue, all these lights I have said AL on them pretty sure. I eventually sourced two AL ones from junkyards for that car.
                    I have no headlights that were from this car originally, those got put on my friends car. I have a set of xenons that were underwater it looks like, a clean set from a rolling shell, and the cheap ebay one pice headlights car came with that also didnt work. So I have one workingish right headlight now, just need the left.
                    The bowls looked okay on these, but I have yet to see it outside of the garage. Right now, I just want two working headlights, car has not had that since I got it. So ordered an amazon ballast, ignitor and some more bulbs for testing it. Looks like someone has been in there with the paint on electrical tape so my hopes for this are low.
                    Build Thread:
                      Ah gotcha, doesn't seem like a Xenon specific issue, but a part compilation situation?
                        Yeah it was a skill issue, was supposed to be a simple fun project but was swapping (junk) parts around for awhile last night and just chasing tail. My old 330 never required me to diagnose Xenon so was a lot of learning last night and works been kinda a nightmare so just a not ideal evening
                        Build Thread:
                          The good thing is everything is the same side to side, you can swap parts from LH to RH and see when the failure follows.
                            I'll do some research on OE or like an aftermarket bulb but good enough for now. Also in the fiasco I did look at the LCM. It was replaced with a dealer one in 2015.
                            A better center armrest is in, RR window regulator replaced with a genuine(ly) used one from the junkyard (it had air freshers shoved in the window frame), right side window switch replaced to fix the RF window.
                            So just one fucky window regulator left, the LR. It's working but oddly stiff.
                            Build Thread:
                              So did get the headlights twerkin, it was just the ballast.
                              We also went through and did the maintenance items. There was a very slight rotating noise, I don't feel like uploading the youtube video. But to everyone else who was around the car assumed it was an accessory noise. So we did that with all the belts, pulleys and tensioner. I also did plugs and coils, expansion tank, all radiator hoses except for one heater hose. Intake will need to come off but the plastic ones were already done on this. Popped in my spare fan E39 530i fan clutch from M3.
                              Car is running great, holding coolant, lights work, windows working, radio working. Was going to to next go to suspension, but I did notice that noise rotational noise was coming back when the engine is warm.
                              Long story short. I found the smoking gun.
                              Car got oil changes!
                              but that timing chain guide is gone. That's about the area noise was coming from, had belt off and confirmed it was engine.
                              Super disappointing, we got a plan. However yea got bit by the higher mileage, not surprising but disappointing.
                              Build Thread:
