Obioban's 2005 IR/IR Coupe
  • Mike RT4
    I'd read through it. Especially if it includes some garage stuff
    This. Me too!
  • Slideways
    Does the house run on a V10? What about the E60
  • heinzboehmer
    Car projects have been pretty slim, because I'm building a house...
    ... should I do a house build journal on here? Everything about the house is unusual construction methods, but this is a car forum, not a house forum...
  • Obioban
  • Obioban
    I was curious to know whether or not you ever got upgraded fuel injectors to support cams and CSL intake. Seems to be a popular subject recently. Looks as though 550cc injectors are being recommended.
    Any thoughts?
    I have not.
    My power curve isn't flattening up top, and my injectors aren't being run at 100%, so I don't see any reason to.
  • duracellttu
    Any thoughts?
  • Allnightlong
    Any new pics of the IR/M it seems like the old pics won’t pull up?
  • Obioban
    Seems like the roof would disqualify you
    Seems like a lot of the JDM guys get by on body panels that were optional on higher spec materials, ala cf roof on the csl. I think I can get in under that.
  • terra
    Gridlife has been adding some events in range of me. NJMP and Mid Ohio.
    Seems like my car would qualify for their street class:
    All classes:
    https://docs.google.com/document/d/e...6WrYdujgPY/pub
  • usdmej
    i've never heard of fender vents / speed holes referred to as "track life style fender cutouts" until now
  • Obioban
    I would hope they update this rule to match inflation.
    ​​​​… strange statement to make on a racing class 🤔
  • repoman89
    Shouldn't
    Until next year
  • Obioban
    Inflation adjusted MSRP limit of $75k is probably going to disqualify you based on the quoted rule set
    Shouldn't
  • repoman89
  • Obioban
    STREET
    STREET is intended for vehicles with minor bolt-­on modifications only. This is our enthusiast class and is intended for advanced HPDE drivers and vehicles that are daily driven street cars, or at least daily-driveable. This class is designed for naturally aspirated 3, 4, 5 and 6 cylinder vehicles, and forced induction 4 cylinder vehicles. V8 Powered cars are not allowed. Rotary (turbo or NA) vehicles are also allowed, if all other rules are followed. Electric cars may potentially be classified in street, based on accelerometer data traces compared to other competitors in class. Street cars must be registered/plated and drivers may be subjected to a “take your spouse for ice cream” impound.
    Vehicles with inflation adjusted MSRPs greater than $75,000 (as of 2022 rules publishing at the end of 2021) are specifically banned.
    CHASSIS / AERO
    • All vehicles must retain stock chassis with no fabricated modifications of any kind.
    • Doors, fenders, quarter panels and roof must remain OEM material.
    • Bolt on alternate materials may be used for Hood, Trunk and Hard Tops.
    • Aftermarket aero is prohibited. Modifications to OEM bumpers to enhance airflow are permitted, but only partial removal of material, not addition.
    • Stock or factory optional aero is allowed if available (this includes aftermarket replica aero and EDM / JDM optional components ie: Replica SiR spoiler etc)
    • Non OEM Flat pan floors are prohibited.
    • Hood ventilation and ducting for the purpose of heat removal is permitted.
    • “Track Life” style fender cutouts rearward of the front tires are allowed.
    • Cars must retain OEM glass. Replacing factory glass with lexan/polycarbonate is prohibited, except in instances of aftermarket hard tops (eg. S2000, etc. ) if sold with lexan/polycarbonate as the only option.
    ENGINE / DRIVETRAIN
    • Dogboxes / sequential gearboxes prohibited unless OEM
    • E85 is permitted. No other alternative fuels are allowed.
    • Mixed manufacturer engine swaps are not permitted e.g., K swapped Miata.
    • Engine swaps with the same cylinder count, and from the same manufacturer are allowed.
    • Forced induction swaps into chassis that are originally naturally aspirated are prohibited. Any questions on engine swaps should be directed to Gridlife staff ([email protected] and [email protected]).
    • Swaps with increased cylinder numbers are prohibited, e.g., V6 Accord motor into Civic chassis.
    • Hybrid Drivetrains are not permitted, unless OEM equipped.
    • Aftermarket conversion of N/A cars to forced induction is prohibited.
    • Turbocharger upgrades to factory turbocharged cars must be stock frame and remain in the stock location. Turbos are limited to a maximum flow of 41lbs/min. Specifically allowed are the Subaru S209 OEM turbo, Blouch 16g XT, HKS GTIII-RS. Additional OEM or “OEM-like” turbochargers may be approved by GRIDLIFE staff following review. Email [email protected] for any questions.
    • Turbocharged cars are limited to a maximum boost pressure of 25psi. Drivers are expected to be able to prove compliance (ie. video, data logs, etc.).
    • Drivetrain changes are prohibited, i.e., FWD to AWD or AWD to RWD.
    • Nitrous is not allowed.
    SUSPENSION / TIRES
    • Vehicles must use a DOT approved tire with a minimum UTQG Rating of 200 or higher. Tires from other markets (EU, JP) are permitted as long as they match the UTQG Rating.
    • Tire Width: FWD: 285, RWD: 285, AWD: 255
    • Tires may only be downsized 10mm.
    • Suspension is limited to single adjustable unless OEM Equipped. Multiple adjustment dampers are allowed with all but one adjusting mechanism completely removed from function. Active suspension components are not permitted unless OEM.
    • Suspension pickup points must remain OEM.
    • The top of the tire may not protrude past the widest point of the wheel arch when viewed from above. Body lines may not be altered overfenders may be added if wheel openings do not change rough dimensions when viewed from the horizontal perspective when fenders are rolled.
    INTERIOR / MISC
    • Vehicles must be street driven vehicles with valid insurance and registration.
    • Vehicles must have headlights, tail lights and mirrors, all in working condition.
    • Roll­cages are not permitted to extend beyond the firewall.
    • Vehicles must retain OEM interior components e.g., dash, carpets, headliner, and all must be in factory positions. (interior may be trimmed or modified to accommodate safety components.). Accommodations for aftermarket racing seats for driver and passenger are allowed. All seats must be track worthy, and capable of safely securing an occupant.
    • Vehicles must have a working climate control system. AC components may be removed.
    • Lexan Glass is not permitted.
    • This class is not open to professionally licensed level drivers (PWC, IMSA, Trans-Am, NASCAR of any level, Formula Drift Pro-1, etc.) Amateur competition licenses do not count as professional.
    All classes:
