Looks great! How’s the ride? Might have to transition form GC coils to your setup or PSS10
2002 Steel Grey 6spd coupe Daily/Restoration project
I upgraded the suspension on my 2004 car, so the hand-me-downs get to be put on the 2002 steel grey now!
To summarize, the suspension is a set of Bilstein B6 HD dampers where I've cut the internal bumps stops down a bit. Then I paired them with mounts that provide more travel and less droop. TMS street camber plates refurbished with new (poly) bushings and axis bearings only like 1,500 miles ago. Rears are Ground control "tall" RSMs (poly) plus GC spec shorty bump stops. I converted the dampers into coilovers with Ground control collars (2.5") and have paired them with 7" 325lb extra travel front Eibachs and 6.5" 550lb rear GC spec Eibachs (also extra travel - barrel). Front endlinks are stock, replaced in last 1500 miIes as well. I also got new F/R sway bar bushings, new rear endlinks, new lower spring pads, and I'm migrating over my rear strut bar. Front strut bar from my 2004 car is already on steelgrey, if you remember. I'm also doing new OE RTABs, but doing OE FCABs at a later time (dropping reinforcement plate).
I'm not reusing any of the stock (124k) parts, so I was able to just pull it all out. Didn't even use spring compressors.
Really enjoyed this setup, especially with a bigger swaybar (Hotchkis), but I'm just reusing the stock bar here. This car is heavier as well, so I may find 325lb to be quite a bit softer, with more body roll, than I'm used to with the setup on the 2004 car. It's a DD though, so that's fine. Lubed new bushings.
Like I mentioned, I'll do FCABs later, so that's it for the front; super easy pre-assembled install. Time for rear, where there's lots more to do. here's the parts pile:
Did fresh RTABs in the rear. I really love my SDW spherical ones in 2004 car, but want all rubber in this car. I love the feel of a fresh E46 M3. Mods are fun to do and might make the car "better" in certain ways, but everything comes at a price.
Original suspension, never touched. Still worked reasonably well. Super dirty.
Did the rear sway bar links/bushings. What a PITA
Good time to update the rear diff bolts! They're no longer fully threaded, so more stout where they support the diff cover bushings.
Took the strut bar out of 2004 car and just painted it black to match the front (it was yellow before). Here, you see it paired with the GC tall RSMS.
Shooting for about 13.5" / 13". Spacers are currently 12mm/10mm, but will go up to 15mm front.
Still need to do some fine tuning, but this was a big step in getting the car to a place where I'm happy with it.
Thanks man! I'm just populating this thread from the IG stories tbh.Originally posted by KhanArt View PostHaven't been on here forever but been following you on IG and love the restoration.
Yes, I try to buy all parts like this - the hella oil level sensor, the CPSs, bosch maf, coils, Lemforder control arms, etc...Originally posted by antknee View Postyeah i hope ppl know those TPS's that are questionably cheap compared to the OEM BMW one....are in fact the same OEM part, just scratched off BMW logo. Have always used those too.
Sent from my SM-G965U1 using Tapatalk
Upgrading the taillights really wasn't on my mind. I even thought I'd keep the car period correct with the pre-facelift, original parts, but, one day, I pulled up behind my friend's '05 CB and the LEDs just looked so damn good. Yes, my 2004 has LEDs, but with the CSL parts, the whole rear end looked different. My friend's '05 is bone stock, so almost exactly like the steelgrey, and it just struck me so.
Didn't look for very long and happened upon an original set from a 2006 325ci on ebay for cheap. The outer tails' grey inner clips and backings (interior light portions) were not included, but I didn't care (don't even use them in my 2004 car). The LEDS all worked and the condition was very nice, so I just bought 'em. Didn't do any research, and got lucky that my LCM (02/02) is new enough to simply flash (think it's after 09/01?). Bought the OE harnesses for $30.
There had been some water getting behind my originals, turns out the foam gasket had split - easy enough to glue back together. Good time to clean the body.
After install, I polished them with an aggressive pad, but mild polish. Love 'em!
Still haven't coded them to get rid of the dash lights - I'm a lazy kunt when it comes to DIY work I don't enjoy.
Das grau boyz together
The car still felt pretty lumpy engine-wise. I've done the plugs and coils, I've run a couple tanks of gas through, fuel filter, air filter, new MAF. The Vanos solenoid made a nice difference, but something was still missing. I knew I wanted to do pre-cat O2s, and how important they are, but I wanted to time that with a header job (more on that later
There was no CEL and no codes (well, one for something stupid, but nothing important to the engine), so I pulled the adaptations to see what's going on.
WTF is this? 5s across the board???
Hmm strange. I didn't think I needed to do the cam sensors, and certainly not the crank or knocks. The only other things I could think of were TPS & fuel injectors. Didn't really think injectors would be too bad at 124k (I did them at 160k on silvergrey iirc), and I could swear I could still hear them ticking away a little (new injectors are very loud). So, I looked into the TPS for the actuator and the front of the throttle rail. Checked FCPeuro, and they do a great job of carrying the OES - the supplier's version of the original part.
Sure enough, these are genuine TPS, with the brand and BMW logo ground off. Save your $!
Gained access, also cleaned out the CCV/Idle control valve. TBs look great. Its funny how dirty and neglected the car is, yet it's a wonderfully original, clean car underneath!
Installed both TPS, and lubed the actuator/TBs' springs and rail (Tri-flow ptfe)
First startup, it already had a smoother idle with not much dipping at all - not sure if that was the ICV cleaning or the TPS though.
Alright alright. MUCH better, the car feel smoother and more responsive! Ignition #s is what I was paying more attention to, but very interesting that the vanos #s went to 0 from -4.5/-1.7. I'm hoping new pre-cat O2s make ignition timing perfect!Last edited by Tbonem3; 08-20-2021, 03:50 PM.
Looking really good wish my engine looked that clean haha, my 02 had all bolts tight and zero hammering too. I still did the disc and updated bolts for sake of mind since I was doing everything else, the chain guide is for sure broken though.
Yasssssss.
Most entertaining thread on this forum right now. I lol'd at the of course dirt under the air duct. Feelsgudman to clean that shit.
Got these codes that might make you think cam sensors, but they're actually indicators of a faulty vanos solenoid
Got a refurbished solenoid and plate seals from Besian, as well as magnets to open the valves to clean the block
Completely forgot to get the chain tensioner guide
As expected
My crude fan tool
So dirty
Look at the oil seepage on the vanos sealing plate - ya they're donzo
Coolant's spraying out of the exp line. Gonna do cooling soon anyway
As Raj says, loosen the pressure actuator before removing block
I needed a little help cracking it loose
Flat as my 1st girlfriend
Cut 'em out.
Separate solenoid and block (tiny e-torx). Seeing the "VANOS" written is pretty cool
Use a strong magnet to open them, and spray brake cleaner through the orifices. O-rings removed from actuator (in background)
Lubed new o-rings supplied with solenoid, and rolled onto actuator. Spray out the filter. I replaced it on my other car, but there's no need if it's in good shape with no chunks of metal
Lubed and installed o-ring. They don't fit too well. You just have to center them as best you can. They'll get squished fine if you tighten the e-torx bolts evenly.
Decided to clean the vanos unit with my go-to red pad and wd-40. I polished it on my other car, but wanted a different look befitting a car that isn't as special/modded. This results in a brushed look more or less.
Solenoid and block back on, connector zip tied
Did the oil filter housing cap and hook as well
Alright, time for valve adjustment. Cover ready to be removed - moment of truth - is my hub fuxd?
Okay okay this is a good sign! Super clean, low varnish for a 2002 w/ 124k. Feeling good here...
Everything looks great. Cam lobes are smooth, no spit shims (would have heard it tbh), plastic gulley guards are present and not cracked.
Here we go. First tab that's visible
Yes! And I'm not seeing ANY evidence of hammering
Numero dos
Fuck ya. Still no evidence of any hammering whatsoever I'm not even exaggerating. I've done my own car and plenty of others' cars and I've never seen it this perfect.
Almost every valve needed a thicker shim. Think it was every exhaust valve and 9/12 intakes. I used so many 2.28s, 2.32s and 2.36s, I had to stop and go to the dealer who luckily still had their box of shims. I was worried when the parts manager said they hadn't adjusted an S54 in a long time. I was able to reuse some old shims, but they were all like 2.16-2.20.
All done
No, I didn't bother with the undoing timing and the cam bolts. IMO/experience, it's the 05s/06s that really had those issues. I also was trained to not fuck with something that's performing beautifully. My 2004 has 180k with original bolts as well, just a besian disc. I believe the vanos stuff is over blown. I believe rod bearings are more like a 150k item, not 100k (many more 200k+ cars on original bearings than 50-100k cars that spun one - also look at the showcase thread where most had more life to go). RACP tears are the only thing I think are a very widespread, almost inevitable issue, but that's a slow moving problem.
Fuel filter time
Did you think there wouldn't be dirt in this cover?
The new filter is pictured - Kayser is the OES part for BMW, not the commonly available Mahle. The Kayser doesn't require an extra copper crush washer like the Mahle does (same size as oil plug I believe).
Hey look, a Mahle, so at least I know it was changed at some point. See the copper washer?
I start by undoing the front connection as the rear connection is free to spin, allowing you to unthread the filter from the block. Then I use needle nose pliers to wedge between the quick disconnect plastic and the filter body to pop it off. I lay a towel down to catch the fuel that will come out. In my experience, it doesn't really help to pull the fuse and let the car die to use up the fuel, fuel will still pour out the filter anyway. Besides that, you can undo pressure at the schrader valve at the regulator, but when I did it, no pressure was released anyway.
New vs old, cleaned up the cover.
Install reverse of removal. I custom made a set of thin wrenches out of some cheap standard open end wrenches. You wouldn't be able to fit a standard wrench in here
I previously documented the regulator swap on the passenger door, but on the driver door, while the window worked fine, the door would not drop the window to exit or raise it to seal. Nor would the center lock button open or lock the door.
Got the panel off, of course the driver vapor barrier is torn as well lol. The deep scratches from getting the panel off are not from me
Found a nice looking actuator on ebay, also from a 2002, with fairly low mileage. Unfortunately, seller didn't disclose that the lock push pin's (don't know what to call it) clip was broken, but I was able to swap my original over.
You can see my previous attempt to remove the tint was frustratingly futile.
Sprayed it with windex, and let it sit out in the hot sun for a while. Then it came off easily.
I found that it's possible to remove/install the actuator without removing the regulator is you just loosen the back 2 nuts and move it out of the way a bit.
New one in. A little tricky getting everything connecting in there.
Ahhh, clean glass! Now both doors' glass is clear with the rear quarters and rear glass still to do.
Window and lock work properly now, though I did have to play with the adjustment of the window so check that (E6? socket, not large) before you put the panel back on. Outer trim piece was also replaced as you can see in a post above.Last edited by Tbonem3; 08-06-2021, 03:45 PM.
this thread makes me want to restore weatherstripping lol.
New seals! Already did the passenger door when I took out the glass for the regulator, but here are the other 3:
While the trims were off, I polished the paint where the edge of the rubber would sit. I'll still polish the doors and qp later, but wanted to get the top flat surfaces done now
Thanks, agreed! IMO, it's a little dark, so in the sun it looks great, but in the shade it looks a bit muddy or dull. Silvergrey is so light, it doesn't really suffer from that, though it can be a little too bright in the sun whereas steel is perfect.Originally posted by skristedja View PostLooking really good, love the paint correction work. Steel grey is a very rewarding color to correct IMO. Looks kinda bland and regular when dull but has a very dynamic depth in good condition. My favorite is in the full California sun when its all clean--it has a nice creamy silver tone in the highlights and a deep almost bluish grey in the shadows. Only reason it doesn't get as much love is because BMW took that and made it even better with the silver grey.
Thank you. Are you talking about looking for defects or how much clear is left? I have fluoro shop lights in my garage so I can see everything.Originally posted by jet_dogg View PostMuch better, good progress man.
Are you checking the paint with a scangrip or playing by eye?
Thank you, it sure does. I also want to remind ppl, I'm behind in updating the thread. All of this content so far happened in only 2 months. I have at least this much more to dump before catching up to present day.Originally posted by K-Dawg View PostThis car has come a long way. It feels good to save a car from neglect.
Is it just the pics that make it look like the sap is on top of the paint and not etched?
No, they look like that in real life too, very frustrating. Spoiler alert* I'm skipping ahead, but I already wetsanded various parts of the car, almost completely the resprayed parts, but I did have a light go (2k) at the sap spots on the factory hood, and it made no difference. They're permanent
It's the greatest eyesore on the car, moreso than the little dents in the upper pillars (that can't come out via PDR). There are also some bird shit etchings mixed in with the sap spots, and a few heavy RIDS. It's by far the worst panel.
