2002 Steel Grey 6spd coupe Daily/Restoration project
  • antknee
    never knew you could replace the windshield gasket on the E46s without pulling out the glass. great job!
  • Tbonem3
    Staying in the engine bay...
    New charcoal filter
    As you all know, the 01 and 02s didn't get front strut braces. I upgraded the one in my silvergrey, so I put it in steelgrey. I also maxed out neg camber in the stock mounts by removing the nipples
    Remove the nuts, and lift the car enough to take weight off so that you can slide the mounts inward. A pry bar helps, be gentle.
ID:	112493 Click image for larger version
    All done!
  • Tbonem3
    Unfortunately (or fortunately), I've made a lot of progress on the car, but didn't update the thread here as I went, so I've got tons of photos to sift through, and my posts here will probably be out of order. So here I'm replacing windshield gasket and cowl and cleaning engine bay, but you'll see the bumper hanging off as I did this stuff before fixing the bumper. It'll get back on track as I catch up here.
    Gross:
    Gasket removed, but still need to clean out the "gutter"
    Was actually really easy to pull old one out and put new one in. Started at one corner and worked my way around:
ID:	112477 Click image for larger version
    Cowl next. Have to pop off wipers. Be careful, it's easy to crack the glass. I used a small puller to get the wiper arm off the spline
    Oh My
    Removed all the plastics, and first blew out the leaves/dry dirt, then washed the engine bay
    I also wash, then soak plastics in a rejuvenator/cleaner. I really like 303, but for heavier duty cleaning and restoration (as opposed to just protecting), I'm actually loving this Meguiar's stuff more. It's a marine product, but wow it works.
    New cowl. Comes with new pop rivets and wiper gaskets, so don't bother buying those separately.
    Wiper arms from silvergrey and newish Bosch wipers:
    Soooo much better lol. The gaskets and the headlights made a massive difference. A paint correction will have this thing looking B+ maybe A-
  • Tbonem3
    MOAR
    Bumper on, getting the trims back in, foglights from the silvergrey (bought new ones for silvergrey), the new(ish) headlights, new grilles
    Click image for larger version  Name:	128sold22.JPG Views:	21 Size:	90.7 KB ID:	112455
    Click image for larger version  Name:	128sold30.JPG Views:	21 Size:	77.5 KB ID:	112456
    Click image for larger version  Name:	silver08.JPG Views:	21 Size:	75.3 KB ID:	112457
    New side emblems and clear lights. Gilles (chrome) were in good shape.
    Click image for larger version  Name:	marcheighth07.JPG Views:	20 Size:	198.4 KB ID:	112458 Click image for larger version  Name:	marcheighth08.JPG Views:	19 Size:	107.1 KB ID:	112459 Click image for larger version  Name:	silver23.JPG Views:	20 Size:	72.5 KB ID:	112460
    Click image for larger version  Name:	silver25.JPG Views:	21 Size:	67.8 KB ID:	112461
    Click image for larger version  Name:	drivewaygrey6.JPG Views:	19 Size:	98.6 KB ID:	112462
    Oil change. PO did an oil change a bit before I bought the car, but it was at a Mobile 1 place and they put in 5w30. So I got cheap LM for now. I'll prob use Castrol next year forward. Only annual changes as I don't drive the daily much either lol
    Da boyz:
    Click image for larger version  Name:	128sold41.JPG Views:	18 Size:	174.8 KB ID:	112465
  • Mpower04
    Motivating me to get back in the garage, great progress!
  • jet_dogg
    84 would be passenger side btw
  • jet_dogg
    Dogg get new door insulation, that shit would drive me nuts it's only 40 bux 51488204283.
    Love me some fresh plastics.
  • 0-60motorsports
    Love watching the work on this brother!
  • Tbonem3
    New bumper guides, liners ready
    Click image for larger version  Name:	fcp12.JPG Views:	0 Size:	75.6 KB ID:	109432 Click image for larger version  Name:	fcp14.JPG Views:	0 Size:	87.0 KB ID:	109434
    Forum member Bassel wanted me to have new oe grills thank you!
    Click image for larger version  Name:	thursday5.JPG Views:	0 Size:	159.2 KB ID:	109435
    Luckily found a set of bimmian painted reflectors in steelgrey for $40! Inventory is low (no longer being made?), some colors are out of luck. Ind has them for $110 iirc.
    Click image for larger version  Name:	20210603_235426.jpg Views:	0 Size:	83.9 KB ID:	109433
    Removed the lower headlights trims and sprayers
    Click image for larger version  Name:	thursday12.JPG Views:	0 Size:	81.1 KB ID:	109436
    Cleaned and conditioned them
    Click image for larger version  Name:	thursday15.JPG Views:	0 Size:	232.1 KB ID:	109438 Click image for larger version  Name:	thursday18.JPG Views:	0 Size:	233.5 KB ID:	109437
    Glued the rubber edge gasket back on at the ends (common issue)
    Click image for larger version  Name:	thursday21.JPG Views:	0 Size:	97.0 KB ID:	109440
    Found like new headlight lenses (AL) on ebay for cheap, score!
    Click image for larger version  Name:	128sold23.JPG Views:	0 Size:	78.3 KB ID:	109443
    Sliding the bumper back on
    Click image for larger version  Name:	128sold12.JPG Views:	0 Size:	199.0 KB ID:	109442
    Click image for larger version  Name:	128sold14.JPG Views:	0 Size:	70.2 KB ID:	109439
    I can tell the bumper's been resprayed. Looks like the rear is too as well as the pass door/qp. I was hoping it was more original, but it's understandable for this 19 y/o car owned by a regular person. PO vaguely remembers, but not why the door and qp. Perhaps keying.
  • Tbonem3
    Thanks guys!
    Lots to post, still have silvergrey content too, but trying to catch up here
    Rear view mirror was leaking, so put in an e34/36/38 era one that I have in silvergrey too from my old 325i. Simple, light, wide.
    Click image for larger version  Name:	thursday6.JPG Views:	0 Size:	186.3 KB ID:	109410
    Took the front bumper/cover off to fix it, using a new pass lower liner and guides, but also remove washer tank/pump
    Click image for larger version  Name:	20210603_235309.jpg Views:	0 Size:	141.0 KB ID:	109409
    Put it in front of Silvergrey and you really see how light silvergrey is. I focus on steel for a while and then see silverg & it looks like tiag to me lol. Imo, steelgrey is too dark, and it just feels very prefacelift I know how that sounds, but I can't shake it. Maybe it's condition makes it seem older too.
    I have to say, honestly, I have an even deeper love of silvergrey after owning steelgrey now for a bit. Steel is too dark except in sunshine, but not dark enough to give the reflections of schwarz. It's a bit lost, a bit muddy. Too much color as well, looks purple brown a lot. In sun, it's absolutely brilliant. Silvergrey in sun is too bright! It's beautiful, but hard to look at without straining sometimes (my eyes are sensitive tho). In all other lights, silvergrey is sublime. It also contrasts better with the non painted surfaces than steel does. Silvergrey is also the (main) csl color ofc, so ya.
    Then there are moments, in the right light where steelgrey looks it's lightest, at first glance, I mistake it for how dark I know silvergrey to get in the right light. It's a trip.
    _
    Sold the 128i to pay for e46. Twas a decent car but nahhhh too goofy, too short of a wheel base. Too cheap inside, too new for me. New owner appreciated the slicktop 6spd which I'm glad about. Adios.
    Click image for larger version  Name:	128sold01.JPG Views:	0 Size:	88.3 KB ID:	109411
    Click image for larger version  Name:	bumper08.JPG Views:	0 Size:	200.2 KB ID:	109412
    Everything was really dirty, but dry, and lots of debris, ofc
    Click image for larger version  Name:	20210603_235647.jpg Views:	0 Size:	180.1 KB ID:	109414
    Hosed it all down, scrubbed it
    Click image for larger version  Name:	image_24598.jpg Views:	11 Size:	213.7 KB ID:	109415
    I then spray anything black (plastic, vinyl, rubber) with this meguiar's product. Same as the professional auto stuff, but half the price. It does a great job at cleaning and renewing. I still like 303 for the interior, but this stuff is just as good, if not better for exterior. Makes the perfect tire tressing imo. You can dilute too.
    Click image for larger version  Name:	20210603_235627.jpg Views:	0 Size:	173.7 KB ID:	109416
    Click image for larger version  Name:	20210603_235727.jpg Views:	0 Size:	160.5 KB ID:	109423
    Ducting after wash/condition/dry:
    Click image for larger version  Name:	thursday14.JPG Views:	0 Size:	82.3 KB ID:	109418
    Tank down and out/disconnected in 3 spots iirc since this car has headlight sprayers.
    Click image for larger version  Name:	washer07.JPG Views:	0 Size:	109.3 KB ID:	109421
    Click image for larger version  Name:	washer12.JPG Views:	0 Size:	78.6 KB ID:	109420
    New lower liner vs old torn up one
    Click image for larger version  Name:	washer04.JPG Views:	0 Size:	194.5 KB ID:	109422
  • jet_dogg
    subbed
    damn lot of work my head hurts just reading this shit man fuck that water
  • 0-60motorsports
    Very nice
  • Maxima SE
    Installed a new outer door trim to finish. All of the trims need replacement
    nice work so far. I have an extra set of brand new trim for the rear 1/4 windows. I'll give them to you
  • Tbonem3
    Got the glass out and put it in the sun so tint just peeled right off
    Click image for larger version  Name:	regulator22.JPG Views:	0 Size:	278.4 KB ID:	108983
    Replacement regulator with motor. You might notice the vapor barrier missing.
    Click image for larger version  Name:	regulator23.JPG Views:	0 Size:	173.1 KB ID:	108982
    So I sealed it up cheaply. Those thick, reusable plastic shopping bags are useful!
    Click image for larger version  Name:	vaporbarrier02.JPG Views:	0 Size:	154.4 KB ID:	108981
    Click image for larger version  Name:	20210603_233413.jpg Views:	0 Size:	71.5 KB ID:	108985
    Checked the areas you might see cracks/separation, in the trunk, and find zero evidence. The same for what's visible underneath. I'm not in a hurry to address the racp (other than add rear strut brace for more rigidity) esp not really driving much anymore with WFH
    Click image for larger version  Name:	20210603_223946.jpg Views:	0 Size:	128.5 KB ID:	108984
    Went to install stereo power wire, and noticed debris down in battery tray so ended up pulling battery out. Seems like water's getting behind taillight.
    Click image for larger version  Name:	20210603_233750.jpg Views:	0 Size:	143.0 KB ID:	108986
    Cleaned
    Click image for larger version  Name:	regulator24.JPG Views:	0 Size:	181.6 KB ID:	108987
    Power wire/fuse holder installed, and battery back in
    Click image for larger version  Name:	20210603_233940.jpg Views:	0 Size:	159.8 KB ID:	108988
  • Tbonem3
    Fixed the broken trunk handle
    Click image for larger version  Name:	trunkhandle8.JPG Views:	0 Size:	85.9 KB ID:	108964
    Then I uninstalled this mess of a sound system:
    Click image for larger version  Name:	SG0223214.JPG Views:	0 Size:	166.0 KB ID:	108966
    Click image for larger version  Name:	SG0223217.JPG Views:	0 Size:	183.6 KB ID:	108967
    I'll clean up the harness later with amp install. Look at this ground they did lol:
    Click image for larger version  Name:	SG0223216.JPG Views:	0 Size:	136.3 KB ID:	108965
    Found a nice looking oem battery under the sub tho
    Click image for larger version  Name:	20210603_222905.jpg Views:	0 Size:	185.9 KB ID:	108973
    Oh there's the bracket and more debris
    Click image for larger version  Name:	20210603_222931.jpg Views:	0 Size:	223.7 KB ID:	108974
    Cleaned the hardboard
    Click image for larger version  Name:	20210603_223624.jpg Views:	0 Size:	232.8 KB ID:	108977
    With new hardware, got the battery secured
    Click image for larger version  Name:	20210603_223703.jpg Views:	0 Size:	185.7 KB ID:	108979
    Pulled passenger door to fix window, they put in some shitty 5.25" coaxials lol
    Click image for larger version  Name:	20210603_223913.jpg Views:	0 Size:	129.0 KB ID:	108976
    The window wouldn't move, no wonder:
    Click image for larger version  Name:	20210603_223825.jpg Views:	0 Size:	105.2 KB ID:	108975
    And the gear wore itself out so I need a motor too
    Click image for larger version  Name:	20210603_223845.jpg Views:	0 Size:	194.5 KB ID:	108978
