Big WHP S54 Track builds
i'm in the same boat, about 3100 with driver/passenger/AC/half cage. if i keep cutting weight then i'll need to figure out how to start towing the car which is not something i'm willing to do just yet.
Originally posted by bigjae46 View PostIt takes a LOT of time.
I would say your build is a bit of an outlier regarding weight
I’ve always thought of an E46 being a Miata with a lot more power. So counterpoint to more power. I’m running at 2900 lbs at 311 whp in this video. Interesting to see the F80 is probably gaining about 2-3 seconds on the straights but still gain about 5-6 seconds a lap. Not sure about the details on the F80 but it takes a lot more HP which only works when you’re full throttle to catch up. I’m about 700lbs less and that works around the entire track. Just a thought if you’re looking to catch GT3s.
And my brake pads are going to last about 8-10 weekends at current wear rate. I use about 20% less fuel and I get an extra 2 days out of tires vs most other E46 M3s.
My car is about 2300lbs with no cage, dry, lithium battery and no passenger seat. I think I’ve drilled over 100 spot welds. Remove every unnecessary bracket, wire, bolt and nut. Trim panels back and remove and elements of comfort, convenience, and style. I even cut the Y bracket under the intake manifold in half...that’s what it takes.
As driven, the car is 2600 dry with cage and w/o passenger seat. I’ve spent about $1300 in weight loss items (lexan windows, sunroof delete, supplies). No carbon fiber up to this point. I’ve gotten as far as I can without spending money.
It’s surprisingly doesn't take a lot of money to make the car light. It takes a LOT of time. The long term goal is to get the car down to about 2475lbs and then replace the cage tubing that is currently 1.5”x.125 to 1.5”x.095. Then it should be at a ridiculous 2425lbs dry. 2675 as raced.
Sent from my iPhone using TapatalkLast edited by bigjae46; 10-29-2020, 04:39 PM.
I’m in the middle of a 288/280 Shrick cam install with turner box and needing a good tune, it’s a fairly expensive mod and I’m really hoping I don’t regret it for some reason that I’m not yet aware of. Any advice from people that have a similar setup? Light weight street car that is heading to do some track days in SoCal.
Yeah fair point, the gt3/gt3rs that are members at my track are more of the 991+ variety so it's pretty tough to keep up with them.
Right, my buddies run 6-7gt3's and we're about the same pace. 991's+ and GT4CS's are a different animal, but you can still harass them in the corners depending on driver 😂
We're in the unclassed HPDE championship, just not front runners.
Originally posted by sc_tr0jan_m3 View PostAt my local track, I'm pulling about 2:10 times with my heavily track prepped m3 and the stock gt3rs's are running in the low 2:03's. There's really just no comparison between the two cars unless you really drop a ton of money into the M3 to compete. I even benchmarked the local NASA racers and with their aero/hoosiers/experience will finally get to a comparable time to a stock gt3.
By the numbers, a CSL-weight M3 with the mods being discussed in this thread should be a bit faster than a stock 996. I'm sure you guys are more stripped than I am (I have carpets), and I'm a bit below CSL weight and probably making some more power.
Originally posted by pMak26 View Post
What headers are recommended? There are a lot of options, some of them very inexpensive. So is it worth it to spend more on some of the pricey headers or are Euro S54 headers good enough on their own?
Only mods left are this and aero. The goal was to chase GT3's, but now I have to chase GT4CS's as well.
How is working with Randy and Epic? Are you having to quarterback between the dyno place and them?
But with Randy, it's been good. Yes, there's many other tuners out there who know how to manipulate tunes, but there's very few people with as much racing experience as Randy. It's been pretty straight forward so far, but yes you're kinda right. You have to either find a friendly dyno shop that's flexible with their schedule to coordinate with Randy. It's a lot of initial setup/flashing/remote connecting to him. I'm gonna be going through round 2 with him after I get my rod bearings replaced.
Originally posted by sc_tr0jan_m3 View Posta stock engine with a good intake, no cats, and a high flowing exhaust can get you to 330-340 whp with a solid tune.
Hey Sam! Who are you working with on the tuning and dyno? I don't really have anybody locally, only place I've heard of is Dynosty down in KY.
Feff
Originally posted by SamGrant951 View PostWassup Rudy! I just went down a "milder" path when redoing the VANOS on my car, more of a while Im in here type thing. My car already had the airbox in place but was running a very unsafe tune (timing advanced / knock detection desensitized 60-70%) - got that straightened out at the same time.
Originally posted by sc_tr0jan_m3 View Posti guess the bigger question is whats your goals with the build? is it chasing 'big whp' or reliability and the ability to run harder and longer at the track? a stock engine with a good intake, no cats, and a high flowing exhaust can get you to 330-340 whp with a solid tune.
i'm at 300 whp and working with randy at epic to clean up my tune to get closer to 340 whp. my times on the track are getting good enough to place in the time trials, even without the extra power. my goals is reliability, manageable temps on the track (especially during the texas summers), and a distant third is power. with my current setup, i can run a full hour without any engine or cooling problems. i run out of gas first before having to back off to cool down the car.
