8/09 Update: Sold!
Year: 2002
Make: BMW
Model: 325iT
Engine: S54B32
Transmission: 6 speed MT
Exterior: Alpine White
Interior: Black leather sport interior
Title: Clean
VIN: WBAEN33462PC10071
Chassis Mileage: 207K miles
Engine Mileage: 175K miles
For sale is a 2002 BMW 325iT that has gone through a full E46 M3 conversion; S54B32, 6MT, differential, driveshaft, brake components, steering rack, suspension components, fuel lines, gauge cluster (coded), DME, engine wiring harness, misc engine bay components, interior bits, etc.
The swap was professionally performed by Kevin ("kaiv") in San Diego, CA. I have owned several E46 M3 platforms in the past and this wagon is well sorted, handles great and will not disappoint. You get the cool factor, cargo room to comfortably take your family on weekend outings AND underneath it all is an E46 M3. If you’re looking for a “sleeper” that you can enjoy with the family and occasional HPDE events, then this is the wagon for you!
The exterior and interior does have a good amount of flaws. However, they are all things that can be fixed. I just want to be as honest as possible for the new owner. Unfortunately, I don't have the time or patience to fix them. Instead, the asking price has been adjusted accordingly. Please see below for the full disclosure. Detailed photos can be found in the link below.
- Paint is original, and still shines. Needs good clay and detail.
- Rock chips on the hood, front fenders and driver side windshield sill. Can be fixed by filling with touch-up paint.
- All four door handles need to be sanded down and repainted.
- Slight tear on the bottom section of the weather strips; passenger front and passenger rear
- Driver side weather strip adhestive is worn. Can be glued down or replaced with new.
- Noticeable scratches and small dent on driver side door sill
- Noticeable scratches on rear driver side door near the side molding
- Crack on passenger side corner lens.
- Small crack on the windshield. Not spreading.
- Windshield rubber seals need to be replaced. Not leaking, just old.
- Headliner has started to sag in the rear (no photo)
- Front seats could use leather rejuvenation to bring them back to life
Now for the fun part. Please see below for a full list of parts that were replaced/overhauled during the swap.
Full M3 mechanical refresh and conversion parts list:
Top end:
Item # BS021 - S54 Vanos seal repair kit
Item # BS022 - S54 Vanos rattle repair kit
Item # BS023 - S54 Rebuilt Vanos solenoid coil pack (x)
Item # BS024 - S54 Vanos sealing plate repair kit (x)
Item # BS025 - S54 Vanos oil pump disk
Item # BS026 - S54 Upper chain guide
11367832031 - Vanos hub (used)
11127832034 - Valve cover gasket
11127831271 - Spark plug seals (6)
11127830972 - Rubber seals (13)
11121437395 - Rubber seals (2)
07119963129 - Copper o-rings (2)
07119963072 - Copper o-rings (2)
07129905536 - Camshaft bolts (12)
11361401971 - Vanos filter
11367831938 - Vanos steel gasket
07119963342 - Chain guide bolt washer
07119963418 - Chain tensioner washer
12120022902 - Spark plugs (6)
Valve shims (12 valves adjusted)
Bottom end:
11247835439 - Bearing shell red (6, WPC treated)
11247835440 - Bearing shell blue (6, WPC treated)
11247834310 - Connecting rod bolts (12)
11131437237 - Oil pan gasket
11137834886 - Rear sump cover gasket
11431707164 - Dipstick o-ring
07129905540 - Oil pump screw
Other engine parts:
11812283798 - Motor mounts (2)
Viton fluoroelastomer CPV o-ring
11287841228 - Idler pulley
11281748131 - Tensioner pulley
11287837898 - Belt (main)
11287830946 - Belt (ac)
Intake manifold clamps (6)
Transmission:
21212229900 - Dual mass flywheel
11222243051 - Flywheel bolts (8)
21212282667 - Clutch part set (incl. clutch disk, pressure plate, release bearing)
11211720310 - Pilot bearing
21511223281 - Pivot pin (stainless steel)
21517570284 - Spring clip
23117512866 - Guide tube
21511223302 - Clutch fork
23121228493 - Input Shaft Seal
22322282340 - Transmission Mounts (2)
21526785966 - Slave Cylinder
61116911072 - Clutch Switch Adapter Lead
Shifter:
25117507695 - Front bushing
25111222015 - Rear bushing
25117580281 - Rod Joint
25111220600 - Cup bearing
25117571899 - Clip (2)
25117527259 - Shift lever performance
Rear end:
AKG SF469 Subframe Mount set (95A)
33172282484 - Front differential mount
33112282482 - Rear differential cover with mounts
Front end:
32301094703 - Steering coupler
32411093597 - Power-steering gasket ring A(4)
32411093596 - Power-steering gasket ring B (2)
17222245358 - Oil cooler line o-rings (2)
Fuel system:
13327831089 - Fuel filter
07119963129 - Fuel filter sealing ring
16111184084 - Fuel pump seal (2)
Fluids / other filters:
13721730946 - Air filter
64319071935 - Cabin microfilter
11427833769 - Oil filter kit
07510009420 - Oil 10w60 (6.5)
Synthetic ATF - Power Steering fluid
82141467704 - Coolant 1 gal
Distilled water 2 gal
83222282583 - SAF XJ + FM Booster 75w140 differential fluid (3)
83220309031 - MTF LT2 75w80 transmission fluid (2)
ATE TYP200 - Hydraulic brake fluid
Misc / extras:
31122282404 - Front headlight level sensor arm
11727831039 - Secondary air tube
11157831311 - Breather hose
11617830104 - Intake gasket
32411712735 - Hose clamp
17121719356 - Hose clamp cap
61138350836 - Cable clip
61130006663 - Wire lead (15)
Stromung custom conversion exhaust
Some notable performance modifications made to the wagon in addition to the items listed above are the KW V1 coilovers, APEX ARC-8 wheels with Dunlop Direzza tires and aftermarket brake rotors and performance brake pads. A ZHP Mtech 2 front bumper can be included for the full asking price (already painted AW).
Overall this is a really fun and reliable wagon, and I hope it finds a good home. Please feel free to message me for any questions that you may have regarding the car.
Asking $20,000
I'm located near Lehi, Utah
PPI and Shipping can be arranged at the buyer's expense
Year: 2002
Make: BMW
Model: 325iT
Engine: S54B32
Title: Clean
Top end:
Bottom end:
Other engine parts:
Transmission:
Shifter:
Rear end:
Front end:
Fuel system:
Misc / extras:
Asking $20,000
