For Sale: 2002 E46 M3, Steel Gray/Black Interior, 114k miles, 6 speed
    2002 E46 M3
    VIN# - WBSBL93472JR17591
    Steel gray/black interior
    114k miles, clean title, 6 speed (swapped). West coast car its entire life, always garaged at home and work, non-smoker, no pets, immaculate interior/exterior/engine bay, purchased at 97k miles in April 2017, full service records since Day 1.
    Key maintenance items during my ownership (these are just the highlights so I don’t drown the ad with too much detail, so feel free to DM with questions)
    • Big 3
      • WPC coated rod bearings (June 2018)
      • Subframe reinforced preventatively with epoxy plates, no cracks found, bushings + motor mounts done (Aug 2017)
      • VANOS Turbotoy hub, new cam bolts, Turner braided high pressure lines, timing chain guide bolt, thermostat seals, pressure accumulator (Apr 2017), Beisan Systems Vanos solenoid coil pack and sealing plate repair kit (June 2018)
    • July 2021
      • Ravenol 10w60 Oil change, Mahle engine oil filter
      • Front pads and rotors (Meyle and PFC08s), Castrol SRF brake fluid, clutch fluid flush
      • New battery
    • Feb 2021
      • Brand new OEM ZCP wheels – mount, balance, ceramic coated before installation, wrapped with brand new PS4S’s with <3k miles
    • Sept 2020
      • Inspection 2 (done early at 110k miles) - Oil change, trans fluid change and flush, diff service, coolant flush, brake and clutch fluid flush, full valve adjustments
      • OSRAM Xenarc bulbs
    • April 2019
      • Oil change, ignition coil pack, spark plugs
      • Steering wheel rewrap, fog lights
      • Steering column clock spring
    • June 2018
      • Full brake service – Meyle front and rear rotors, PFC08 pads, Castrol SRF brake fluid, SS brake lines
      • Full suspension refresh - Koni Yellows, EIbach pro kit springs, OE front upper strut mount reinforcement plates, complete rear upper shock mounting kit, Lemforder FCABs, Syncro Design Works RTAB bushing kits, OEM front swaybar end links
      • Apex Race parts spacers (15mm front, 12mm rear with compatible lug bolts)
      • Oil change, oil level sensor, Blackstone sample (clean bill of health)
      • Door seal trim, steering wheel trim
      • Seatbelt tensioner replacement, CV joint and diff mount replacement
    • Aug 2017
      • Inspection 2 (done for comprehensiveness post-purchase), Oil change, trans fluid change and flush, diff service, coolant flush, brake and clutch fluid flush, full valve adjustments, updated CPV O ring, clean all lock slider mechanisms, OEM guibo
      • Six speed swap with brand new OEM parts, CDV deleted. Still shifts like new
    The car has been maintained religiously by Dan Avon (our Bay area E46 M3 savant) for most of the items since 2018 so you’ll have great provenance and familiarity. One thing we’ve noticed recently is that there is some popping of the spot welds between RACP and chassis on the driver side wheel well. Diagnosis is to continue monitoring and do a topside reinforcement kit if it progresses (most folks don’t do). However, I just wanted to be 100% transparent. I’ve also included a picture to show this. Car comes with 2 remote keys.
    In summary, this is the 5th M car I’ve owned over the years, and it’s been a blast to own and drive. Zero leaks, and paint (aside from an underside bumper scuff, and 2 tiny scratches) is gorgeous. No door dings/swirl marks, and interior is pristine with no rips/tears/blemishes. All recalls (rod bearings, airbags) have been taken care of promptly. No accidents/stories/drama, just a fellow enthusiast looking for the next lucky owner to continue to drive and enjoy her.
    If the ad is still up this is still for sale. Located in the Bay Area (San Mateo). Price - $32,500
    Clean and well sorted out. Good luck with the sale.
      very clean car, GLWS!
      -Singh
      2004 e46 ///3 | Laguna Seca Blue | Black Leather | 6MT | Coupe | OEM+
      BBS RC | Supersprint | Ground Control | Besian | Euro
        Man this is nice! GLWS
          Beautiful. Why are all the nicest cars on west coast. GLWS.
