Up for sale is my 2006 BMW E60 M5 SMG in Interlagos Blue on Silverstone Full Leather with 107k miles. WBSNB93546B582010
As seen in the title, the vehicle is a mechanic's special. The vehicle struggles to start most of the time, it cranks and stutters to try to start but wont fully start. Once it does fully start, it idles smooth but the vehicle is in limp mode and will only go forward and backwards about 3-5mph. It will not pass 2k rpm as well. It seems that the vehicle is running only 5 cylinders due to the codes 2B57, 2796, 2B40. From what I have found, the bank 2 ionic module is not getting any power, hence the 2B40 code. I am not an electrician and am not too familiar with how to chase wires as I am more mechanically minded. Vehicle must be towed and cannot be driven home
Below are some recent maintenance history of the vehicle:
1) SMG Pump, Motor, Hydraulics done at 98,800 miles @ B&B Autohaus
2) Clutch Replaced done at 98,800 miles @ B&B Autohaus
3) Alternator done at 98,800 Miles @ B&B Autohaus
4) Diff seal done at 98,800 miles @ B&B Autohaus
5) New BOSCH Fuel Pump 107,000 miles
6) New Rear window trim seal 107,000 miles
7) New Battery 107,000 miles
8) New Valve Cover Gaskets ~100,000 miles
Below are the mods it has:
1) H&R Lowering springs
2) Aftermarket M Style Wheels (Not sure if OEM or not, seems to be from a later model M car)
3) RR Muffler
4) AFE Intake System
5) Black front Grills
Below are the options on the vehicle:
1) Heads up display
2) Keyless entry and engine start
3) Full leather
4) Heated and Cooled seats
5) Active side bolster seats
6) Alcantara headliner
7) Rear heated seats
8) Upgraded sound system
Cons List:
1) Electrical engine issue mentioned above
2) Driver side mirror paint peeling
3) Roof mouldings clearcoat peeling
4) Some clearcoat fade on rear right door
5) Hood paint matches but is cracking in some spots
6) Center console arm rest worn and torn
7) Leather Dashboard cracking
8) Sharkfin antenna clear coat peeling
I am more than happy to share videos and answer any questions you may have. Vehicle has a Salvage title due to a front end accident in 2012. Located in San Diego, CA
$10,000 or best offer. Willing to accept trades as well.
3) RR Muffler
1) Heads up display
3) Full leather
Cons List:
