SOLD SOLD SOLD
All Receipts I have for the work/parts
Maintenance:
Mileage Date What was done:
1546 1/2/2002 BMW 1200 Mile service
12760 11/11/2002 BMW Oil Change/MP Service
25562 9/27/2004 Inspection 1/ Brakes/Brake Fluid change (full maint program)
25562 9/27/2004 Rod Bearing Recall was done
39265 11/13/2006 DME Reprogramming
40695 1/31/2007 Sold to Westchester BMW
41004 7/26/2007 Typeslice bought the car from M3forum.net
07/2007-06/2008 or 41000-61300 indicating an oil change
61319 6/10/2008 BMW Inspection II
74535 7/16/2009 BMW Oil Change
86101 6/28/2010 BMW - Oil Change, AC service, new Freon
91935 8/16/2011 BMW - Oil Change and wipers
100466 9/19/2012 Sold to me! My ownership starts here
101244 9/22/2012 Oil change and drain bolt
101425 10/15/2012 Installed ST coil overs, BMW Rough Road Plates, Brake FluidFlush
102XXX 11/5/2012 New Front rotors and pads. Rear- pads only
104XXX 11/29/2012 Cold Compression test and spark Plug replacement. OilSeparator replaced
105XXX 4/7/2013 Valve Adjustment and VANOS bolt replacement. No bolts were loose, replaced with the updated PN and Loctite. Work done by Tonggi from theM3Forum.net
105XXX 4/24/2013 Subframe Reinforcement, AKG plates and new AKG bushings all around rear subframe and diff. NO Cracks or Tears in the chassis.
106XXX 5/15/2013 Installed Rogue Engineering Front Sway Bar and Front Strut Bar. Oil Change and filter/bolt
106XXX 6/20/2013 Bought TCKline SA setup
107XXX 8/20/2013 Vanos Hardline Replaced. Oil Change and filter/bolt
107XXX 9/27/2013 Installed Rogue Engineering Rasp eliminator sec 2 with new bolts
1085XX 12/10/2013 New passenger side seat belt receptacle
109XXX 2/12/2014 Replaced TC Kline SA Koni Yellow rear shocks with new units
111235 3/15/2014 Diff Fluid drain/refill, new plugs
111235 3/15/2014 Trans drain/fill with OEM fluid, Brake Fluid Flush
1115XX 4/6/2014 Installed BMW OEM Tie Rods
112102 4/26/2014 BMW Oil change and filter. Alignment
112XXX 6/20/2014 Oil Change and filter
113XXX 8/10/2014 New BMW Front FCABs, Motor Mounts and fuel filter, Brake Fluid Flush
113XXX 9/01/2014 New PFC Direct Drive Rotors installed up front with new PFC pads
114XXX 10/23/2014 Replaced Rear TC Kline springs with new TC Kline rear springs(600lbs)
114XXX 11/5/2014 Bought new Height Adjusters for the rear springs.
115414 2/6/15 Passenger side airbag replaced under warranty
115470 3/15/15 Installed rear height adjusters with new ones (new ones from 2014)
115470 3/15/15 Replaced front TCKline single adjustable shocks. Also got new collars and hats. Also new TCKline camber plates.
116047 5/12/15 Replaced rear differential input seal. It had a slow leak that was starting.
116047 5/12/15 Installed Status Gruppe Scorza SGT muffler. Used new OEM HW
117235. 8/15/15 - oil and filter change.
117235. 8/15/15 - put on a leather steering wheel. Replaced the Alcantara one that came on the car. 117410. 8/29/15 - Rebuilt front caliper, good as new, piston looked great
117410. 8/29/15 - installed turner solid guides for the front calipers
117610. 10/21/15- oil and filter change, belt inspection , air filter inspection
117800. 2/5/16 - Installed SPC rear camber arms installed. Bimmer Clinic did the work
118100. 5/3/16 - WPC Rod bearings installed Thanks Coinage!! (Thanks M3dragonfor the WPC treatment!!) New CPV Valve special vibruton Oring ( Thanks Mpower22), New Steering coupler, O2 sensor, Oil and filter change!
118650 - 6/2/16 - oil and filter change
120101 - 5/14/17 - oil and filter change
121410 - 7/16/17 full interior swap from grey to black, heated, power lumbar with brushed aluminum trim
122010 - 7/16/17 installed new Bimmer world large shift knob.
123010 - 5/3/18 - new left rear driveshaft. New not reman.
123010 - 5/3/18 - BMW Motorsports 4.10 gearset installed by Tyspeed
123212 - 7/21/18 - New PFC direct drive v2 rotors installed and new PFC 08compounds up front. New Centric rotors in the rear
123212 - 7/21/18 - brake fluid flush
123293 - 8/12/18 - oil and filter change
124673 - 8/6/19- Cooling overhaul - New OEM radiator, new Tstat, water pump,hoses, end connectors and removal of the manual fan.
- Added in a Mishimoto Puller Electric Fan conversion and wired up the fan controller.
- Replaced Front windshield cowl
- Replaced rear window lower weather seal
- Replaced rear window upper weather seal
- Drained and replaced Diff fluid (per break in with new 4.10)
- New Hood vent cowl piece
124863 - New gm5 module rebuild (lock/unlock)
124863 - Bluebus install
124863 -Microphone install in headliner
125479 - 6/20/20 oil change
125683 -8/30/20 - New PS Pump, All hoses and reservoir. new fluid
9/16/20 -Lemforder front tie rod drivers side.
9/16/20 -alignment
7/27/2021 -dealer installed New oem pass side door lock module.
126555 -12/30/2021 Besian vanos sealing plate orings
126610- 3/23/22- new hood struts.
Maintenance:
9/16/20 -alignment
