Selling my 2003 E46 M3. Carbon black on Black leather. I’ve owned the car for about 6 years. Previous owner was in Texas. Car now resides in New York. I love this car but with 2 small kids, no longer having to commute to work because of remote work, it really pains me to just have this car sitting. It's only done about 1000 miles the last 2 years. I'm not in any rush to sell but I hope a fellow member can continue to drive and maintain her.
Asking $20,000
PRICE DROP: $18,500
Upgrades/maintenance:
- Turner Motor Sports subframe reinforcement kit (welded)
- AKG 75D (red) poly subframe bushings
- OEM rear trailing arm bushings (RTABs) with poly limiters
- OEM differential mounts (all 3, including new differential cover)
- Stoptech SS brake lines all around
- Koni Sport (yellow) adjustable shocks/struts all around (15k miles)
- pads and rotor on all 4 corners (10K miles)
- new OEM strut bearings
- new OEM upper and lower front spring pads
- new strut mounts
- New FCAB
- Milltek section 3 (done by previous owner)
Last 5,000 miles ago
Features:
- Xenon headlights
- backup sensors
- Pioneer stereo with Bluetooth
The good:
- no codes
- no leaks
- no worries
- engine pulls like a champ
- SMG in great shape, with crisp shifts
- Black leather interior is in great shape. Sight bolster wear on driver’s seat.
The bad:
- a few small dings (shown in the pictures)
- foglamp lenses are cracked, but still work well and replacements are cheap
- Headliner starting to sag
- A, B, C pillar cloth removed because they were peeling
- Stone chips
- Clear coat starting to fade/dull on roof.
- Needs new tires -These 18's were the tires when I first purchased.
Extra’s
Asking $20,000
PRICE DROP: $18,500
- Vanos done.
- Subframe reinforcement done
- SMG relocation done.
- Rod Bearing TSB recall 07/26/2005 13,903 miles- Have not touched under my ownership.
- new strut mounts
- New FCAB
- new OEM throttle position sensor (TPS) - the one under the intake that's a bear to get to
- Full Vanos Beisan rebuild done by “Dan the Vanos Man” in Westchester (drilled oil pump disc, upper chain tensioner guide, seals and anti-rattle, solenoid, upgraded bolts etc.. )
- valve cover gasket and valve adjustment
- new OEM water pump
- new OEM thermostat
- new Valeo alternator
- new AC belt and tensioner pulley
- new waterpump/alternator belt and tensioner pulley
- new OEM coolant temperature sensors (one on radiator hose and one under intake by thermostat housing)
- new CPV o-ring
- B-spec tune with SMG CSL rev match and inertia fix
- Coby Alcantara wrapped steering wheel
- Storm Motorwerks Paddles and Shifter (and shifter surround)
- SMG relocation to the drug bin
Features:
- Xenon headlights
- backup sensors
The good:
- no codes
- no leaks
- no worries
The bad:
- Stone chips
Extra’s
- OEM section 3
- Burkhart SMG motor with extra temp sensor and installation tool
- 1 salmon relay
