SOLD 2004 M3 Carbon Blk/ Imola 6spd in SOLD
    2004 M3 in Carbon Black on Imola Red interior. This M3 is ready to be driven. I have had a ton of recent maintenance done to it. I was planning on tracking this car so I wanted it to be ready without failures.
    Present mileage is 126,844
    @123,000 miles Rod Bearings W/ ACL bearings and ARP bolts
    Vanos was done with all new parts
    Oil pan gasket
    Valve cover gasket
    spark plugs
    water pump
    thermostat
    radiator hoses
    A/C belt Alternator Belt
    Clutch
    flywheel
    throwout bearing
    front driveshaft damper
    @125,000 miles Subframe reinforced with Redish V3 top and bottom plates. Everything cleaned & reassembled looks like new underneath
    All new rear bushings and ball joints
    Diff Cover and Fluid
    Turner rear Control arms
    CMP Solid Subframe bushings
    Syncro Design works RTAB
    Drive Shaft support
    Engine and transmission mounts
    Stainless Brake lines Ecs Brass Caliper Bushings Calipers, Rotors, pads all around
    Evap Canister leak detection pump
    DSC pressure switch
    TPS sensors
    Constant Pressure Valve
    Ohlins Road and Track with Flat Ride spring rates and its corner balanced. Rogue Engineering Rear Shock Mounts and Turner Motorsports Camber Plates
    Volk CE28SL wheels 18x9.5 with Hankook RS4 265/35/18 Wheels are mint not one scratch.
    Cobra Nogaro seats but also have the Original mint condition Imola seats.
    The Car has the typical wear for a 2004. Rocks chips etc. but no dings or dents. There is a crack in the windshield I was planning on getting replaced. Also the drivers side fog light is cracked but I have a replacement.
    Some pixels out on headunit.
    No check engine lights or codes.
    Car is tight and runs perfect. Clean Carfax, no accidents.
    SOLD
    SOLD
