For Sale: 2003.5 Jet Black E46 M3 - Manual Transmission
    Hi all,
    I am selling my 2003.5 Jet Black M3.
    I have owned the vehicle since the 105k mark.
    The car has 160k currently.
    All work has been itemized in the spreadsheet attached with Mileage, Part Manufacturer, Part # and Costs. The total is $27,000.
    This car has been mostly worked on from friends / associates of mine at BMW North America’s Engineering Department.
    Brief Summary:
    - Full Cooling System Refresh / Replacement
    - Vanos Unit Rebuild
    - DriveShaft Rebuilt
    - Epoxied Turner Motorsport Rear Subframe Reinforcement Plates
    - Every Suspension Bushing replaced
    - Rod Bearings were done at 10k on the odometer under recall
    Some Notable Features:
    Engine:
    - RPI Intake Scoops
    - Rouge Engineering Intake Elbow
    - Custom Software (Shift Lights, Launch Control, etc.)
    - UUC Motorwerk Pullies
    Cooling:
    - Mishimoto Radiator
    - Mishimoto Radiator Hoses
    - Mishimoto Electric Fan
    - Rogue Engineering Coolant Vent Line
    - ECS Aluminum Coolant Bleeder Screw
    Suspension:
    - Ground Control Coilovers: Front: 525 lb. / Rear: 650 lb.
    - Ground Control Hybrid Camber Plates
    - Rouge Engineering Front Strut Brace
    - BMW Front Shock Mount Reinforcement Plates
    - Rogue Engineering Front Control Arm Bushings
    - Rogue Engineering Rear Shock Mounts
    - Rogue Engineering Trailing Arm Bushings
    - ECS Rear Lower Control Arms
    - Powerflex Rear Lower + Upper & Outer + Inner Bushings
    - Hotchkis Front and Rear Sway Bars
    - Hotchkis Front and Rear End Links
    - Powerflex Differential Bushings
    - Powerflex Rear Subframe Bushings (Black: 95A durometer)
    Brakes:
    - StopTech Front and Rear Drilled Rotors
    - StopTech Front and Rear Pads
    - StopTech Stainless Steel Brake Lines
    DriveTrain:
    - OE Luk Clutch
    - OE Luk Flywheel
    - UUC Transmission Mounts w/ Enforcers
    - UUC Clutch Line
    - E60 Short Shift Kit
    - UUC Dual Shear Selector Rod
    - Spring Detents
    Wheels / Tires:
    - Apex ARC-8
    o 18 x 9.5 ET35
    o 15MM Turner Motorsport Spacer in the Rear
    - Michelin Pilot 4S
    o Front Tire: 255/40-18
    o Rear Tire: 275/35-18
    Interior:
    - Full Power Seats
    - Adjustable Bolsters
    - Carpeted M Mat - Trunk
    - Carbon Vinyl Wrap
    Exterior:
    - Bi-Xenon Lights
    - Smoked Corner Lights
    - Painted Front Reflectors
    - CSL-like Rear Diffuser
    The vehicle is located in Rockland County, NY
    Asking Price $27k or best offer - Please see the attached Excel Spreadsheet.
    Some pics:
      The following will be included with the car:
        Plus:
          And Lastly:
          1 Set of Winter Wheels 18 x 8 (TR Motorsport) - I believe they are 18 lbs. ?
          Tires are not in good condition for prolonged use.
          1 Front Passenger Seat (full power w/ Adjustable Lumbar).
            More Pics:
              Bump
                Bump
                  I see a bunch of pictures of parts, but none of the actual car - did i miss a link?
                    I think it’s a problem with TapaTalk.
                    I will try to update via the website!
                    Thanks for bringing this up!
                      Pictures are fixed.
                        Sold
