2002 BMW M3 Race/Track Car
    For Sale: 2002 BMW M3 Race/Track Car
    FOR SALE 2002 BMW M3 - BMW $50,000
    52k miles. Major Refresh completed.
    Exceptional HPDE car! Was built for BMW HP class, but great baseline for AER/WRL/BMW club racing
    Liquid Moly sponsorship paid for the wrap, which can be removed
    $29k in Suspension and Mechanical Refresh completed in last year by Morehead Speedworks (Details below)
    · Engine Refresh – 4 Track hours
    · 327 HP / 259 TQ Epic Tune Dyno Results
    · Valve Job
    · Matched Injectors
    · BE Rod Bearings & ARP Rod Bolts
    · Rear Main Seal
    · Motul 300V LeMans 10W60
    · Oil Cooler Aeroquip AN Fittings
    · Rogue Race Pulley Kit
    · Heater Core Delete & Block Off Panel
    · New Accessories: Water Pump, Alternator, Starter, Vanos Rebuild (Beisan)
    · Coil Packs and Plugs, Knock sensors, Throttle Position Sensors
    · Turner Motorsports Air-Oil Separator and catch can
    · Morehead Speedworks (MSW) Engine, Transmission and Differential Mounts
    · Refreshed ZF 5-speed Transmission, Sachs Presure Plate, M5 Clutch Disc, Throw Out Bearing
    · CAE Shifter
    · AP Brake Calipers Rebuild / Castrol SRF Brake Fluid
    · MCS 2 Way Dampers Rebuild, BMW Strut Tower Reinforcement Plates
    · Full Chassis Setup with Corner Weights, alignment, ride height
    · Install New MSI Race Studs and Nuts
    · All Power and Ground related wires upgraded and streamlined: Cartek Battery Isolator, New Relays, Voltage Regulator, Optima Battery
    · EGR Delete Kit, Breather Filler Fuel Expansion Tank, Fuel Line
    · Refreshed rear axel
    · AERO: Moorehead Speedworks Quick-Disconnect Front Splitter
    · Lexan rear quarter side windows and rear window.
    2021-2 Refresh
    - Replaced ABS module and wheel speed sensors
    - Replaced front and rear hubs and bearings
    - Bimmerworld Dual Fuel Pumps
    - Front windshield
    Other Upgrades/Parts:
    Epic Motorsports Headers & Bimmerworld Race Exhaust
    CSF Radiator and Oil Coolers, SPAL Race pull-style fan
    Z4M Power Steering Rack with adjustable tie rod ends
    AP Racing front brake kit (2023 rebuild), Ferodo Pads, Rear Brass Guid-Pin upgrade with Pagid pads
    Cold Air Intake, aFe Throttle Body boot, heat block off box
    Aim Dash and Expansion Module: added sensors for Fuel Pressure, Air-Fuel Ratio, Oil Temp
    Aim SmartyCam data acquisition integrated HD camera
    Bimmerworld Rear wing, BMW M3 Flat-bottom undercar panels, Hard Motorsports dive planes, Carbon front splitter
    AKG Front Race Control Arm Bushings
    Hotchkis Front Race Swaybar, AKG Race Swaybar end links, Ground Control Race Camber Plates and Rear ride height, Synchro Design Spherical Bearing RTABs, Ground Control Front Control Arm Bushings
    Turner Motorsports Rear Race adjustable camber arm set, Synchro Design Works Spherical Bearing RTAB
    Race Differential - Synchro Design Works 4 Clutch
    Race Louvers R/T Hood Louvers
    Full Cage, compliant to BMW Club Racing regulations
    Driver and passenger door window inserts for storage and element protection.
    RaceTech Halo Drivers seat, Racetech seat mounts, Sparco Passenger Seat and mounts, Schroth 6pt Harness
    Coolshirt System
    Sparco Steering Wheel, narrow hub mount, and quick disconnect
    18x9.5” Wheels, 5mm spacers
    Electronic Bentley Service Manual, Torque Spec Manual, and Electronic M3 Owners Manual
    Receipts for parts and services for history of the car
    Car is located in northern Atlanta suburb. More photos available upon request. Contact Rick Grande at e-mail Rick.Grande@hotmail.com
    MVP Track Time
    🥺 what are you moving onto Feff​​​​​​
      Not me selling. It's my friend Rick's M3.
      Feff
      MVP Track Time
        Ad on Racing Junk:
        MVP Track Time
