Enthusiast-owned. No accidents, with consistent paint measurements throughout. I am the 4th owner. The 3rd owner was another enthusiast who transitioned to the E92 platform but invested significantly in this car. The 2nd owner was an older gentleman who kept a meticulous log of all the work he did. The CSL has always been my dream car, and this was the closest I could get. I drive this along with a 6-speed 997, and now I’m looking for a modern daily driver. I’ve been pleasantly surprised by how good the SMG system is with the CSL flash - it has such a mechanical feel versus 8ZF or DCT.
Car is one of the cleanest E46 M3’s you will find. No rock chips/dings that you would normally find on the e46 platform. Most of the work has been completed in the past 5-10k miles – Vanos/Rod Bearings/Brakes/PPF/Wheels & Tires/Suspension.
Had Lang Racing take a look at the subfame, they said no signs of crack from the usual spots but suggested the RTAB's need to be replaced which I went ahead with.
• Ohlins R/T Coilovers with Vorshlag camber plates
• Karbonius Carbon CSL Trunk (have OEM original)
• Status Gruppe CF Front Lip
• Status Gruppe CF CSL Diffuser
• Borla Exhaust (have OEM original)
• PPF on entire front end, side skirts, side rocker panels
• Clear Ceramic tint
• SMG CSL Tune
Recent Maintenance:
Prior: Replace power steering hose into steering rack, replace A/C belt, replace constant pressure valve,
6/2019 Oil change, valve cover gasket, air filter, fuel filter, cabin filter, spark plug, gear oil, ATF transmission fluid
4/2021 65,397 Rear differential fluid, oil change. Alignment.
5/2022 67,256 Respray Front clip, rear diffuser, rear trunk lid $4500
PPF Full front, rockers, CF front lip $2700
9/2022 67,905 Oil Change (10W-60 RAceTec 1), Brake Fluid, CSL Trans flash, Manual Transmission fluid exchange. Drained transmission fluid, added 1.5qt febi manual trans fluid, relearn procedure. $1100
3/2023 70,204 Install Ohlins, Rebuild Vanos, Perform Valve Adjustment, Replace Valve Cover Gasket, S54 Vanos Seals Repair Kit. Rod Bearings replaced, Change oil, Engine mount. $4600
Ohlins Road & Track $3000
CSL Karbonius CSL Trunk $2000
12/2023 73,000 Rear Powerstop Rotors rear, Hawk Ceramic brake pads rear, New Windshield Wipers, Brand New 19” Apex Arc8, Michelin P4S, Rear Trailing Arm Bushings, Alignment. Leather Refresh. Center Console refurbished. Ceramic tint installed. Borla exhaust install.
1/2024 Installed OEM alarm system, coded with Carly
1/2024 2 Stage Paint Correction, Ceramic Coat Mckee37 Paint Coating
1/2024 72,990 New OEM front and side grills. Hawk Ceramic front pads, adjusted dampers to +7
1/2024 73,000 Liqui-Moly 10-60 oil change and filter
6/2024 Repair A pillars, repaint speaker grills, Replace front brake rotors to Powerstop. New steering wheel.
• SMG CSL Tune
Recent Maintenance:
