We've just released our latest versions of these mounts. They now include an open mounting slot, so they are easier to install/remove. This also increases compatibility with aftermarket radiators that may have slightly different upper and lower rail locations. We've yet to run into a radiator that these do not work with.
We recommend using these mounts with a SPAL 30102049 fan. This fan provides sufficient airflow even if you retain AC in a hot climate. Others have opted for thicker fans, although clearance to the engine will be reduced. You can run a low-profile fan as well if you need additional clearance.
Our mounts include an optional mounting plate for the AUX fan controller. Includes all mounting hardware.
We are running a 10% off promotion for this forum through the end of May. Use coupon code NAM3F at checkout.
Installation DIY: https://thebuildjournal.com/diy/n15-...fan-mount-diy/
http://n15design.com/product/n15-des...ric-fan-mount/
