IND | Fall-Line Motorsports E9X M3 / E82 1M Carbon Ceramic Caliper Bracket Set
    The Fall-Line Motorsports E9X M3 / E82 1M Carbon Ceramic Caliper Bracket Set is designed to seamlessly retrofit the front and rear brakes on your E9X M3 or E82 1M BMW to the carbon ceramic brakes offered on the F8X M3 / M4. Originally only offered as part of a brand new and complete carbon ceramic retrofit brake kit (IND-E9X-34112358378), we have now made the caliper brackets available separately so you can source your own used components.
    This bracket set provides the essential hardware required to install the BMW F8X carbon ceramic brake calipers on your E9X M3 or E82 1M. In addition to retrofitting the F8X carbon ceramic brakes, these caliper brackets also let you retrofit the 6 piston front and 4 piston rear calipers with steel brake rotors from the F87 M2 Competition!
    One the one hand, carbon ceramic brakes offer superior stopping power, reduced brake fade, significant weight savings, and minimal brake dust when compared to comparably sized steel brakes, making this an essential upgrade for true performance enthusiasts. Additionally, the F87 M2 Competition steel brakes offer massive 400mm x 36mm front rotors and 380mm x 28mm rear rotors with equally giant 6-piston calipers front and 4-piston calipers rear.
    Fall-Line Motorsports’ bracket set ensures that the installation process is secure and are precisely machined, which includes pocketing that both minimizes weight while maximizing strength to guarantee no failures even under race track conditions. As a final touch, the caliper brackets are anodized in a hard coat black finish.
    Made in the USA: High-quality materials and craftsmanship for a reliable and durable upgrade.
    Vehicle Applications:
    • E82 1M Coupe
    • E90 M3 Sedan
    • E92 M3 Coupe
    • E93 M3 Convertible
    The Fall-Line Motorsports E9X M3 / E82 1M Carbon Ceramic Caliper Bracket Set may be viewed at the following link to our online store:
    Upgrade your BMW E9X M3 and E82 1M with a Fall-Line carbon ceramic caliper bracket built for track use, strength, and motorsport durability.
    Please contact IND by phone or email for more information or to place your order.
    866.963.4520 | [email protected]​
    Works with the following brake components (not included):
    1. F8X M3 / M4 Carbon Ceramic Front and Rear Rotors with Gold Calipers
    2. F87 M2 Competition Steel Front and Rear Rotors with Silver Brake Calipers
    IND DISTRIBUTION | 847-963-4520 • INSTAGRAM • FACEBOOK • YOUTUBE • FLICKR
    That looks like a well-engineered solution for E9X M3 and E82 1M owners looking to upgrade to F8X carbon ceramic or M2 Competition steel brakes. The weight savings and performance benefits are definitely appealing, especially for track use. Have you already sourced the calipers and rotors, or are you still considering the full setup?
      I may be misunderstanding you, but this is an ad for the brackets that we developed with Fall-Line (quite a number of years ago actually), but we never sold them on their own. We used to only offer the full Carbon Ceramic conversion kit with the brackets and all new parts; unfortunately the component pricing from BMW has become so prohibitively expensive that we've decided to let customers source their own parts. We have sold and installed both F8X CCBs and F87 M2C brake components on the E9x M3.
