IND | Burkhart Engineering E46 M3 SMG2 Pump Relocation Kit
    The Burkhart Engineering SMG2 Pump Relocation Kit for the E46 M3 and CSL is the ultimate solution for optimizing the functionality and accessibility of your SMG system while prolonging its health by relocating the SMG Pump, Motor, and Accumulator system away from the heat of the engine block. Designed with precision and performance in mind, this kit is widely regarded as the best on the market for its comprehensive features and exceptional build quality.
    What truly sets this kit apart is the thoughtful inclusion of a dedicated provision for mounting the CSL's SMG fluid reservoir that is missing from other available kits. This integrated feature ensures a clean, professional setup, streamlining the relocation process while maintaining a factory-like appearance.
    When it comes to relocating your SMG2 pump, the Burkhart Engineering kit delivers unmatched convenience, reliability, and functionality.
    Product Details:
    • 54696 - Relocation Bracket: Engineered for perfect fitment, ensuring durability and ease of installation.
    • 54379 - Extended Hydraulic Lines: Plug and Play OE Connectors and premium-quality lines designed to maintain optimal hydraulic performance.
    • 54230 - Wiring Harness Extension: Plug and Play OE Connectors and factory-insulated quality extended wiring harness to simplify integration without compromising reliability.
    NOTE: CSL SMG reservoir not included; only suitable for vehicles that do not have the ABS unit in the passenger side engine compartment bin.​
    The Burkhart Engineering E46 M3 SMG2 Pump Relocation Kit may be viewed at the following link to our online store:
    https://ind-distribution.com/product...relocation-kit
    Please contact IND by phone or email for more information or to place your order.
    866.963.4520 | [email protected]
    IND DISTRIBUTION | 847-963-4520 • INSTAGRAM • FACEBOOK • YOUTUBE • FLICKR
    Do you have any installation documentation?
      Unfortunately we don't have documentation, but there have been some DIYs on YouTube and there may be some good information on this forum.
      In a very brief nutshell:
      1. Drain SMG hydraulic system
      2. Remove intake manifold and affiliated parts
      3. Remove the hydraulic lines and harness from hydraulic accumulator/motor module
      4. Connect extended lines and harness
      5. Install relocation bracket and hydraulic module in passenger side compartment and connect lines/harness
      6. Install CSL SMG reservoir on relocation bracket
      7. Refill system with pentosin and run SMG bleeding procedure via INPA or take to a certified BMW tech
