We’ve recently updated our Burkhart E46 M3 catalog at IND. As E46 M3 enthusiasts ourselves, with several team members owning multiple E46 M3s, we’ve always appreciated the unique parts Burkhart offers. To make access even easier for fellow enthusiasts, we’ve expanded the catalog with more SKUs at IND and are keeping them in stock, ready to ship.
Burkhart Engineering E46 M3 CSL Airbox Snorkel - Round Inlet
https://ind-distribution.com/collect...airbox-snorkel
Product Details
Burkhart Engineering E46 M3 CSL Airbox Snorkel Round Hose Adapter – Angled
https://ind-distribution.com/collect...adapter-angled
Product Details
Burkhart Engineering E46 M3 / M3 CSL Carbon Intake Front Air Scoop
https://ind-distribution.com/collect...ront-air-scoop
Product Details
Burkhart Engineering E46 M3 Carbon Front Air Duct
https://ind-distribution.com/collect...front-air-duct
Applications
Burkhart Engineering Magnetic Oil Sump Drain Plug - M12x1.5
https://ind-distribution.com/collections/m3-e46/products/burkhart-engineering-magnetic-oil-sump-drain-plug-m12x1-5
Product Details
Burkhart Engineering Magnetic Differential Oil Drain Plug - M22x1.5
https://ind-distribution.com/product...n-plug-m22x1-5
Product details
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | [email protected]
Product Details
- Manufactured from 3D-printed PA-CF (carbon fiber reinforced nylon)
- Mechanically and thermally stable for reliable long-term use
- Fits both OEM and Karbonius CSL airboxes
- Optimized airflow with reduced intake temperatures
- Also compatible with E36/7 Z3M S54B32 and E85/E86 Z4M with trimming
- Straightforward installation (deletes OE CSL intake flap if equipped)
Product Details
- Manufactured from 3D-printed PA-CF (carbon fiber reinforced nylon), offering strong mechanical and thermal stability for long-term use.
- Designed to fit both OEM and Karbonius CSL airbox snorkels without additional modifications.
- Angled adapter with round outlet (83mm) to bolt up to standard round hoses used on many intake or ducting setups.
- Helps maintain or improve airflow efficiency by connecting OEM-style CSL snorkels to more universal ducting options.
Product Details
- 100% carbon fiber construction
- Manufactured in an autoclave for maximum strength and precision
- Designed to lower intake air temperature by channeling additional fresh air directly to the intake system
- Fits both E46 M3 and E46 M3 CSL applications
- Made in Germany
- Motorsport part
Applications
- E46 M3: Part no. 55613-01 (replaces OEM 13717830100)
- E46 M3 CSL: Part no. 55613-03 (replaces OEM 13717834085)
- Manufactured from premium carbon fiber for strength and weight savings
- Direct replacement for the OEM plastic scoop
- Draws cold air from the front kidney grilles to the intake or CSL airbox
- Available in versions for both standard E46 M3 and CSL models
- Designed for motorsport applications
Product Details
- Lightweight Aluminum Design – 30% lighter than the OEM plug without sacrificing strength.
- Strong Neodymium Magnet – Captures and holds ferrous particles created during engine operation.
- Pass-Through Hole – Allows for the installation of a safety wire to prevent loosening
- OEM Compatibility – Direct fit for BMW applications, complete with the original BMW aluminum sealing ring.
- Precision Fitment – Manufactured to exact tolerances for reliable installation and long-term durability.
Product details
- Aluminum Construction – Lightweight yet durable, designed to OEM standards.
- High-Strength Magnet – Efficiently traps ferrous particles suspended in the oil.
- Direct OEM Replacement – Supplied with sealing washer for a precise fit.
- Trusted Upgrade – A simple but effective part that adds protection with every service.
- Thread Size: M22x1.5
- Includes: Locking screw (magnetic core) and sealing washer
- OEM Reference: Replaces BMW part number 33117525064
