New Goodyear Eagle F1 Asymmetric
  • $w!ft
    I think I got it. So if I want to run my goodyear F1's on the track I should make sure they run about 32-35 psi hot.... Which means I might have to take some air out.
    On the road I should leave them as 32-35 psi cold as they will never warm up properly...
  • shimmy
    Originally posted by $w!ft View Post
    https://nam3forum.com/forums/forum/c...-cups-on-track
    This thread says differently.
    Pardon my ignorance but if I read this correctly then I should run 33-35 psi cold on road conditions then deflate to 26-28 psi cold for track conditions?
    those are all relating to track where you get 4-6 psi gain with temperature increases.
    All manufacturer recommended inflation pressures are based on cold tyres.
    * I run my PS2 road tyres based on 35psi cold
    * I run my track Cup tyres based on 26psi cold (as their pressures generally increase to an optimal 32-33psi when hot)
    Hope this helps clear your confusion! :thumbs:
    more or less same here (we gotta stop agreeing)
  • glendog74
    I thought i answered this one already... :whistle:
    The recommended pressures according to the sticker on the door pillar are (iirc) 2.4 bar all round = 35psi
  • $w!ft
    Ive just bought a set of 2nd hand Michelin Sport Cups off Justin for a track day at Oulton Park this saturday. What pressures do you reccommend in dry coolish temperature (10 oC). Says 30 in the maunual i think but maybe this is a bit high for track use?
  • shimmy
    Originally posted by anissut View Post
    So 30psi cold = 35psi hot? Can anyone confirm?
    i run my PS2 at around 33 front and 35 rear cold for general road driving, a bit higher than usual but reduces edge wear
    cups i keep at 32 front and rear (they do seem to generate more heat and therefore pressure gains even on the road)
  • anissut
  • $w!ft
    Really?
    So is it cups that should be run at 32 PSI HOT, around 26-28 Cold, not Goodyears?
    Im confused
  • mattCSLnut
    I think you'll find they're under-inflated!
    I run my Goodyear Eagle F1 on the fronts @ 2.4 bar and the rears @ 2.2 bar :thumbs:
  • glendog74
    Conflicting info alert! :smt017
  • glendog74
    What PSI are you guys running with Goodyear F1?
    Just checked my tyres cold this morning, think they are over-inflated. This is what I got:
    Front Left: 24 PSI
    Front Right: 29 PSI
    Rear Left: 30 PSI
    Rear Right: 30 PSI
    Shouldnt it be around 27-28 PSI Cold?
  • $w!ft
    Front Left: 24 PSI
    Front Right: 29 PSI
    Rear Left: 30 PSI
    Rear Right: 30 PSI
  • glendog74
    Originally posted by Nords View Post
    :whistle:
    Had all four fitted today by some great lads at Kwik-fit
    My most recent tyre fitting experience was at Kwik Fit in Sandhurst and i was pleasantly surprised by the service level - against all expectations...! :thumbs:
  • Nords
    :whistle:
    Had all four fitted today by some great lads at Kwik-fit in the middle of Swindon (next to the Shell garage). Coped with the lower suspension without a drama, fitted all four without marking the rims, filled with nitrogen and swapped a cup over on my track rims without charging for it.
    235/35 & 265/30 for £750 all up! Car feels much better and softer on the bumps already. My old rears were slicks less some tread on 3" on either edge!
  • $w!ft
    Do you guys go anywhere specific to fit your tyres? Or just go to any local garage
  • md23
    What about 245/35 and 275/30? Certainly cheaper for GY. I reckon you could get a full set for about £650 by shopping around t'internet and asking Kwikfit to price match.
    Not sure what else available in those sizes. I just put new GY rears on 265/30 as I had a puncture and realised that I had 275/30 on before... :banghead: Now I have one OK (4mm) 275/30 in my garage. Fat lot of f*cking good that'll be then...
    Thought the GY were OK but nothing to compare against as that's all I've had on the CSL.
    m
