We have a fantastic offer on for the CSL Register.
Rouge engineering power pulleys for the M3 CSL
ABOUT POWER PULLEYS
By gearing down the fluid resistance accessories (water pump, power steering), less engine power is diverted to spinning the pumps, thereby allowing your engine to spool up more quickly and produce more overall power.
Kit includes replacement water pump pulley, power steering pump pulley and new serpentine belt.
No detrimental effect whatsoever to your car's cooling and steering system, as by about 5000 revs the pumps are already working at their maximum capacities.
Whereas some other aftermarket pulley kits also include a replacement alternator pulley, we do not subscribe to this method of reduction. By reducing the alternator's ability to provide adequate voltage to the system, you may encounter electrical issues or system shortfalls not covered by the manufactures warranty.
On most modern BMWs, the crank pulley does more than just drive the accessories (water pump, A/C compressor, power steering pump, and alternator), it acts as a harmonic balancer for the crankshaft of the motor. When you remove this weighted, balanced component from the front of the motor and replace with a lightened, underdriven crank pulley, you can accelerate internal engine component wear since the crank is no longer weighted on this end.
Some companies offer just a crank pulley, which when underdriven, will then underdrive ALL of the associated accessories. This can lead to serious engine damage.
Each Rogue Engineering Power Pulley kit comes complete with installation manual and high quality replacement serpentine belt.
We offer these in two versoins
1. Street version
£ 190.00
2. Race version
(RACE pulley kit includes underdriven alternator and crank pulley. This pulley kit is STRICTLY for dedicated track/race cars (not cars that see street duty). A/C is no longer used. This is the same kit used on the Grand-Am Automatic Racing M3s. The crank pulley has been designed to accept a dry-sump cog. The STREET and RACE kit use the same size belt
£ 390.00
We need a minimum of 5 orders to offer 15% Off the website price making them
£161.50 for street version
£331.50 for race version
Delievery will be within two weeks when we have the minimum of 5 orders paid for
thanks phil
ABOUT POWER PULLEYS
1. Street version
£ 190.00
2. Race version
£ 390.00
thanks phil
