10mm spacers - do they fit?
    Quick question for anyone running standard suspension and OEM CSL wheels.
    Will the fitment of 10mm spacers at the front cause rubbing?
    My car has around -2d camber on the front
    No - not at all. I have used 10mm at the Ring & Spa with no issues on OEM suspension with -2deg camber set on top mounts. :thumbs:
    Shimmy uses 12mm all round without problems (with Intrax 1k2) and i think Mark uses 15mm at the front on his car.
    I might try the 15mm on the fronts...
      I've 10mm's all round on KW suspension, no issues with rubbing even on full lock.
        Thanks guys - good to know! Will be putting on a set then :beer:
          I spoke to Thorney on this as they recommend 10mm at front for improved handling on standard set up......I'm going this route to.
            WTF?! :hahaha:
              front turn in supposed to be improved with spacers but i put mine all round and they seem to have welded themselves to the rims :bigcry:
                I got told that too, but I went 10s all round to keep that bad-boy-staggered look. :supz:
                  yeah me to :thumbs:
