The ring
    The ring
    Can i use a camcorder on the ring ? if not how do you lot set up the camera so they dont see it ??:whistle:
    No. If they see it, they will make you turn around, and if you do it twice, banned.
    That's the official take. When I used my bullet cam I just pulled out, pulled over at the exit a little way out and set it up. I did get told off by an official once for stopping there with the other that had stopped but mostly it's ok. I however decided I'd prefer to drive than get banned so only recorded one lap.
    Oh, saw one guy throw a coat over his cam - worked. Other times I've had my bullet mounted and not using it and they haven't seen it. Risk you take.
    Cheers,
    Jeff
      Give Sabine a big kiss and you'll be grand .
      Ah sure as you say your self .... You'll pull away !
      Seriously , be discreat mount it after you go through the barrier if you can
