Bounce hasn't got an hour in him :whistle:
CSL v's M3 - Exact part differences needed!!
I think you will find that some of the items above are actually exactly the same as the standard M3 item.Originally posted by alexk View PostOf course, I analyzed each and everyone of them [sic] and here are some interesting finds that we were not aware of.
12517833366 - Wiring harness, engine grbx. module (1.83kg) // Normal M3 with SMG 1.87kg
13717832175 - bumpstop
13717834085 - suction hood http://bmwfans.info/parts/catalog/13717834085/ (0.419kg) // Normal M3 0.470kg
17112282380 - water + oil radiator http://bmwfans.info/parts/catalog/17112282380/
25162282560 - shift knob alcantara http://bmwfans.info/parts/catalog/25162282560/
31332282508 - bumpstop
33532282503 - rear damper adapter
51477896369 - floor covering front http://bmwfans.info/parts/catalog/51477896369/
51477896370 - floor covering rear http://bmwfans.info/parts/catalog/51477896370/
61116975073 - main wiring harness http://bmwfans.info/parts/catalog/61116975073/ (16.51kg) // Normal M3 18.93kg
61672695531 - Head lamp cleaning device container http://bmwfans.info/parts/catalog/61672695531/
61677892701 - Windshield cleaning container http://bmwfans.info/parts/catalog/61677892701/
64546928033 - Compression shroud http://bmwfans.info/parts/catalog/64546928033/
72117919207 - seatbelt http://bmwfans.info/parts/catalog/72117919207/
Some times BMW sell particular items as a complete build up unit rather than individual items and list them differently for different cars - but it is actually the same as the standard M3 item.
The only items in the above that is actually different to the standard M3 are:
Interesting about the interior carpet - it seems it is LHD cars only - which leads me to suspect that the lighter carpet only came in the LHD cars and not the RHD cars - the reason - the RHD cars have the same carpet as the standard M3.
But awesome program!! I did it all manually originally when I compiled the list.
DISGRACE - I want my money back! :119:Originally posted by NZ_M3 View PostInteresting about the interior carpet - it seems it is LHD cars only - which leads me to suspect that the lighter carpet only came in the LHD cars and not the RHD cars - the reason - the RHD cars have the same carpet as the standard M3.
Yes, the manifold of cylinders 4-6 is different between LHD/RHD.Originally posted by _Nathan_ View PostWhy do they have more power? Do they run a different manifold as that is the only difference made possible by having the steering wheel on the correct side.
I don't know what is the number but in the older days the RHD were usually 5bhp down because of the different exhaust manifold.
Originally posted by NZ_M3 View PostI think you will find that some of the items above are actually exactly the same as the standard M3 item.
Tom, are you adding these too ?
BTW, no info about color codes.
There is a lack of knowledge at BMW M.
I asked for the chassis stiffness, they didn't know the number.
Having said that. I somehow doubt what they said.
I personally think we need to count the welding points, the ones visible and compare them to a normal M3.
artyman:
:blalalala:
