Nothing wrong with this corner provided you brake before the brow and treat it as a wide hairpin with a very late apex. If you brake after the brow you're off early. If you get the power on before the apex you're off late!
TIP; after braking before the brow aim for the traffic lights on the bank and turn in late, then apex late and let car run to the end of of the rumble strip on the outside of the corner. Anyone who tells you they can brake after the brow in a road derived car is dreaming or driving too slow!!
Ive done Castle Combe just 2 weeks ago and saw this video before. I think its just inexperienced drivers mainly, that corner has a ridiculously late apex
The corner has a huge straight leading to it so braking is very heavy for it, braking is also over a crest and the line through the bend is not the easiest.
It is not that tricky to fathom out though. I think the main problem is that you can go on track there quite regularly for £20 a session so the type of driver will be very different to on a track day!
Depends in what car you're in really... the instructors will say aim for the middle where the marshalls post is. The natural line is to go as wide as possible, but then you have to set yourself up to brake diagonally in a straightline.
In my Elise i never made the corner no matter what line, so generally just headed straight for the apex.
As said, the crashes are down to mis-timing of braking, normally on the rise just when the car has no grip...
I personally never saw the problem, but then i don't need to brake until after the rise is done, being a fucking legend.
It is at the end of the fastest part of the circuit, if you make it over Avon Rise and the slight left hander there, this corner then catches you out!
Sounds like QUARRY corner :whistle:. I have to say I find braking from 135 mph trough Avon Rise (before Quarry) more dangerous, as the surface is bumpy and causes the car to undulate :119: while braking and turning left slightly, upsetting the ABS and the dynamics of the chassis. Maybe it's just me :smt017
