Thanks for the help:thumbs:
So bump will infact control things like rear end squat and diving under braking.
Based on no experience at all I would have thought that a soft to moderate bump and harder rebound would suit our roads?
Rebound and bump for idiots
Most probably - as Shimmy always does... :clown:Originally posted by dontdobends View Posthe's pulling yer chain snoopdog
Go on then, tell me all about your personal experience of KW V3's or Clubsports as fitted to your M3 CSL & why there isn't enough adjustment... :whistle:Originally posted by shimmy View Postyep
There is also no 'right' answer, I tend to prefer very stiff springs and very soft damping as (IMO) it allows greater adjustment of grip over a wide range of applications, but other people prefer a very soft spring and very hard damping, its a case of whatever works for you.
Generally soft = grip but it comes at the expense of overall speed.
lol.
I'm writing an article for a magazine about car set up so the full detail will have a wait (its a 5 page article) but in essence:
Spring - holds the car up and combined with ARB controls some aspects of the cars roll, stiffer spring means car will roll less but means it will take more of a bump to get it to compress (I wont go into progressive rates etc).
Compression (bump) damping - controls the speed at which the shock compresses when hitting a bump in the road, on 3 way suspension this is split between high speed and slow speed. High speed means high speed compression, ie hitting a kerb, slow speed is more transissional; undulations in the road. So, if you have a ride where the car feels too crashy over bumps then its likely your bump is too hard and needs to be softer. However if you go too soft the chances are the spring is too hard for your needs and you're better off changing a spring rather than running damping on full soft.
Rebound damping - this controls the speed the shock extends after compression, rebound tends to control the speed at which the car retains its balance, if the car feels bouncy the chances are the rebound is too soft and is reacting too quickly so you need to stiffen it up.
Add in tyres, wheels, ARB's, ride height, camber, castor, trail, toe, mono tube/twin tube, aero and driver style and you can see why it takes some time to really develop suspension for road or track. In development we tend to use three way adjustable (4 way sometimes buts its hard work) to set up damper settings which are then used on the less adjustable shocks for the road. Takes me 2 full days to set up a race car from scratch on three ways for example and assumes about three spring rate changes.
Originally posted by sunnybonoHi,
There appears to be a lot of experience with KW suspension on this forum so I thought I would pose the question... how does bump and rebound affect my ride quality.
I have read the pdf on thorney website but am having trouble relating to real world and my setup. For example, the pdf suggest rebound impacts dive and roll, whereas I thought softening off my compression (bump) would result in a great weight transfer, and ultimately grip?
Which setting has the greatest impact on ride comfort? ie help soaking up bumps and ridges while just cruising?
Thanks
Most effective way of improving ride quality is by......
Going back to OEM as KW has a poor range for road settings
Hi,
ThanksTags: None
