Hello guys I need to replace my AP discs on the front. Pretty disappointed with the AP ones as they still look like they have loads of life left in them but at Cadwell yesterday they were humming like buggery then started to warp with more heat. I left them to cool and the warping went but the terrible humming noise is still there. Any suggestions???? I'm also thinking while Im on to buy some bells for the rear and change them from the standard CSL discs. I have the AP calipers front&rear. Cheers guys:thumbs:
AP Disc replacements????
cant do itI'm also thinking while Im on to buy some bells for the rear and change them from the standard CSL discs. I have the AP calipers front&rear
performance friction are the only rear set up that comes with a separate bell, the AP are the same floating disk as the OEM disks. Most people seem to put the PF disks on the AP front alloy bells when replacing the AP disks
Exactly what I was thinking - what pad are you running?Originally posted by shimmy View PostTake out the ferrodo ds2500
It is unlikely that you have warped the disc and far more likely that you have pad deposits that have built up from an overworked pad.
AP discs do crack but if they look like they have a lot of life left in them I would be tempted to run a hard pad like an RS29 to try and clean up the surface first.
