Clutch Slur
  • mattCSLnut
    :gayfight::hahaha:
    :thumbs:
    i am not one for always taking the DSC off, def not in the wet. M track is usually on for half a day at least mainly to cut downt he risk factor but nearly always finish the day all systems OFF if it is dry
    There was ice & snow @ Bedford on the 30th so excuse me for leaving DSC on :blalalala:
  • shimmy
    the DSC stayed firmly ON and was kept occupied :hahaha:
    :gayfight::hahaha:
    Originally posted by SpineOnABap View Post
    . DSC OFF is the cure
    :thumbs:
  • shane@mbtech
    NO... no rising revs + the fuel tank was half full and it didn't feel like fuel starvation. The ambient temperature was between -2 and 2 deg C plus this being my first outing at Bedford, the DSC stayed firmly ON and was kept occupied :hahaha: Great turnout despite Siberian winter weather :whistle:
    Pussy:gayfight::gayfight::gayfight::gayfight::gayf ight:
  • SpineOnABap
    Hi Matt, that would almost certainly have been your DSC taking over (even if the dash light wasn't activated!). It would have done the same in M-track mode too. The DSC software doesn't always activate the dash light when it's doing it's thing. It's surprising how much it interferes on those full throttle redline shifts even when the temps are high and you're on sticky rubber like MPSC. DSC OFF is the cure
  • mattCSLnut
    What does this mean:smt017
    What level was your fuel at? ,I had similar issues always out of a chicane with between 1/4 and empty tank. I try not to run too low on fuel on track now, never had the issue since.
    Did you have dsc completely off? or in M track?
    Slur as described here is clutch slip so your revs rise then slur back down as clutch bites. Your symptoms sound slighhtly different
  • shimmy
    be careful on track as said as it can feel like cluch slur a bit as you can get fuel starvation on long corners then onto the straight (but never had it at Bedford - but coppice at Donny it alwasy happens about 1/6 tank)
  • danr55
    so does changing to S1 for a couple of days then changing back seem to fix it?
    Any other specific fixes?
    Don't fancy driving in S1 just to find out it doesn't improve anything!:hahaha:
  • shane@mbtech
    I had something resembling what's been described as "Clutch Slur" happen to me @ Bedford TD yesterday. SMG in S5, SPORT on , 2nd into 3rd full throttle and a BIG flat spot, with a delay in execration. Very strange :smt017 Keep in mind my clutch has been changed under warranty along with a new Duel mass flywheel only a year and 8000 miles ago.
  • Bounce
    Don't know about the design, Dan. Something's different enough to cause this issue though.......
    I had an E46 M3 SMG before the CSL and it didn't have this problem during the year I owned it.
    I had an SMG M3 for 4 years before the CSL,and never had one problem with slur.
  • mattCSLnut
    Sadly it's not caused by driving style, otherwise we could prevent it. It's caused by shit design. It's the only thing I really HATE about CSL, and it's been bugging me since 2003 so it's a good job I really like the rest of the car :hahaha:
  • The Gorilla
    Hi,
    E46 M3 SMG 2 has a 'MAF' where the CSL does not.
    The infamous CSL clutch slur is as a result
    of the way the throttle inputs are received
    by the ECU/DME and the commands it makes
    based on the data received.
    The 'Alpha N' type arrangement on the CSL
    works on throttle/load there is no air
    reading as such.
    Regards,
    The Gorilla.
  • SpineOnABap
    I have a gut feel that the clutch slur issue us an easy fix bit it's just that nobody has worked out what it is yet!
    You could well be right Shim! We (the CSL community) have been banging on about this issue since we first encountered it in 2003 - 7 years and still none the wiser. BMW clearly didn't care......
  • SpineOnABap
  • danp
    Is the design different from normal E46 M3 SMG? (apart from software)
    They don't slur so much do they?
  • shimmy
    Does the M3 SMG have the same problem?
