RTAB tool
    RTAB tool
    Hi does anybody have the tool required for the RTAB removal, this job doesn't look that bad and I'd like to do it but wondered if anybody localish has a tool they can lend me or otherwise does anybody know where I can rent one - if that is possible.
    if ur careful ,they can be easily drilled out.or use a couple of good quality sockets and a vice .hope this helps
      site seems slow tonight?
      Thanks cosmicboy, are you using a vice in situ? Thinking about I may have a go with a few G clamps. Can somebody give me an idea of what's best. Ploy bushes or std bushes with limiter or poly bush and limiter?
        dont think poly bushes need a limiter
        my philosophy is that poly bushes will shake the car to bits withiout as cage - so stick to rubber
          so std rubber bush and a limiter then? I expect if I'm going to go as far as fit the limiters then the bush should be replaced?? oem or is there a better bush without going poly?
            To be honest I'd just buy the tool rather than muck around with a drill.
            I did mine with a tool and it makes life a whole lot easier having one and much faster too. You'll also be less likely to damage stuff.
            Got mine from here: I also have the FCAB one too, but have not used that myself.
            Standard bushing + limiter is a great setup (I use the Vorshlag limiter kit and find it to be pretty good)
