Something weird happened to the CSL
    Was driving home from work today sitting at a steady 50.
    Decided that id stick on the Aircon for the 1st time this year and run it for the 20mile journey home just to circulate the gas etc.
    Now the car has done around 300miles since going back on the road about 3 weeks ago after its winter rest and has ran perfect.
    Aircon had been on for no more that 10sec when the dash / radio / heater display went blank. I could just make out the gear indicator and i mean just, really really dull.
    Quickly switched the aircon off again but everything remained the same probably for another 30secs before returning to normal.
    My 1st thought was that the Aircon pump had seized causing belt dammage to the Altenator / belt but kept going and got home.
    Lifted the bonnet once home and tried the Aircon again and confirmed that the pump and belt are ok and operating fine.
    It's in the back of my head......"altenator" but i have had no light flickering, dodgy starting etc
    Any ideas?
    Have Croft in 2 weeks so need the car to be tip top
    On a happier note came home to my new Cups waiting for me:banana::banana::banana::banana:
    Cheers,
    Originally posted by rstoughy
    Any ideas?
    Use your CSL more often! :hahaha:
      The same happened to me a few weeks ago had changed the wheels over the night before for a trackday on the way there the next morning the steering took a little jerk to the left and then all my display dissapeard all came back before 5mins and no problems during the trackday. Prolly maybe because i didnt do the reset both paddle back thing after wheel change earlier..
        :thumbs::thumbs:
          Any ideas?
          Cheers,
          Could be one of those unexplained gremlins. Or a first sign of alternator failure,
          Give shimmy a bell, last I heard he was trawling the scrapyards for alternators to recondition as spares..... just in case:whistle:
            :hahaha: :hahaha: :hahaha: thats what i'm thinking, might just keep it taxed through the winter this year.
            Seems they dont like sitting around. (have got 59K on the clock though )
            Done the SMG reset the other day as it was getting a little jerky.
            Ran fine since and i've not touched it, just the 40mile round trip to work for the past few days.
              I had the same issue 3-4 times.
              Problem was the battery (low voltage).
              This was also the fault recorded in the ECU.
              Yes, the alternator is charging, but if the battery is fecked up, E46 tends to do these things.
              Get a c-tek charger, leave it on the car and it will fix the battery
              I invested in the charger and didn't have to change the battery.
                Talking of weird shit i complained about a noisey steering pump a while back and was out this week and took a left hander at sensible speed and the steering went rock hard (missus was hoping) i then straightened up and its been fine ever since but still a bit noisey at low speed! I had it on the ramp also and noticed that both rack boots had sucked in almost as if their was a vacuum in the rack any ideas. I would just add about the battery charger that batterys need to cycle ie: charge and discharge.
                  I use an Oxford Maximiser battery conditioner on it if it sits for any length of time.
                  Have used this for years on all my cars and bikes and it cycles the battery.
                  Will check the date on the Batt tomorrow as it could well be the original so might be due a change.
                    Happened to me about 9m ago exactly as described. Also think likely a gremlin - had no prob for 6m after (but have now just replaced alternator)
                      Had it a couple of times over the years - those damn gremlins :whistle:
                          Little fookers.
