My 1st CSL track day / How good are cup tyres?
    if you're that good on "normal" tyres then nothing will come past you with CUP's on...
    Cup tyres rock! There is a considerable difference between road tyres & Cup tyres - especially with their cornering grip ability :thumbs:
    Cups wear rather quicker than road tyres of course :bigcry:
      Totally agree, I've done a couple of trackdays on Michelin Pilot Sport's this year which were ok but overheated and 'went off' after a couple of sessions, I've also done a couple of trackdays on worn Cups and the grip and difference is night and day IMO!
      The Cups not only allow longer sessions due to withstanding the heat better they obviously allow for better lap times due to the grip!
      All I can say is get some, don't worry about them in the rain either, I personally don't think they are bad at all and have not had any 'moments' at all, either in greasy semi wet conditions or full on wet roads! :thumbs: :thumbs:
        Originally posted by shepp80
        I used road tyres and had a lot of fun and was still very quick.....how much better can the Cup tyres be??
          Mine was fine on 265 rears mate, I've got a mate who can do full fat Cups, fitted and balanced with new valves for £1100 the lot!
          I don't know if they can deliver, I can get a cost for just the tyre's and collect them for you, you'd just have to courier them the rest of the way if you like?
            RIGHT!! im sold! :thumbs:
            where is the best place to buy cup tyres? :hahaha:
            i currently have 275/30/19 on the rear,i know the standard are 265.
            shall i go back to 265??
            yes you have to
            only CSL 19 inch sizes are 235/35/19 and 265/30/19, try Elite Tyres, Blackboots, Protyre, Costco, Camskills(if you have memebership will be cheapest)
            dont buy Cup+ by mistake like some knumbskulls
            Cup left, Cup+ right
              265 30 19 rear
              235 35 19 front (dont get cup +)
              cha-ching...you are £1200 poorer
                yes you have to
                mytyre is another good one to try and I have a link on the work PC I can check tomorrow, might be someone else to try
                  Cup+ are :gayfight:Shim! LOL
                  Are there also Cup N0's or something? (Sure I've seen something else listed by them!)
                    Cup N1 or N0 are just porsche approved - doens really matter, they can be used BUT just make sure they are not Cup+ with the extra rain channel and wider channels
                    Some bedtime reading
                      if you want to save money my 4 recommnedations
                      1. get adjustable front camber plate or adjustable suspension
                      2. dont overheat them so keep say below 15 minutes on track and pressures 32 or under all times 9dry)
                      3. swap them over between track days if circuits are all right handers or left handers
                      4, get them heat cycled before use if ou can (£40)
                        Ok great!!
                        what are cups+ then??? some one explain???...please
                        as said above they have a wider rain channel as per shimmy's pics, and they are not the same compound.
                          thanks Shimmy! and thanks for the cups+info......
                          I bought the car with KW 3 and ap's.
                          do i need to look into getting adjustable camber plates as well, do you think?
                          Heat cycled?? £40??
                          Heat cycling alters the rubber compound and helps prepare it for track use
                          You may adjustable front camber plates fitted, if not the ability to alter front camber easily by 1 degree helps grip but also reduces tyre wear
                            DSC off means you have ABS only left working, no TC or active driver aids.
                            S6 on the SMG only is available when DSC is OFF
                              ok thanks.....i thought the camber looked more than standard.
                              another thing...am i right in thinking...S6 mode is basically everything switched off, traction wise?
                              or does it do anything else?
                              Correct, DSC has to be off to enable S6 so zero traction control and 0.08s gearchange :smokin:, in M-Track mode S5 is max and DSC is set to around 40% IIRC
                              Posted identical time to Shimmy! lol
