weight info for parts...?
    I'm sure You know this:-)
    oem front seat weight ? thinking if change can help here, probably not much
    rear seat removal - 17kg (already seen thread)
    supersprint back box - 15kg? just guess
    big brakes probably same weight are close
    lighter wheels probably does not exist or not much
    /I know air con can be removed and radio and speakres, but these i want to keep/
    You can save around 1.5kg per wheel by choosing a lighter style.
    Front seat replacement will save a fair amount of weight also as well as removing all the crap from the boot.
      2.2kg actually with Volks :smt055
        recaro pole postion seats are pretty light
        This seat is also available in an ultra-lightweight Carbon-Kevlar CFK Composite, ideal for fitting to vehicles where shedding weight is a priority. The Carbon-Kevlar Pole Position ABE only weighs an incredible 4.5kg - perfect for the driver searching for the optimum racing performance
          be a bit careful as sat weights are always given ex cushions, mounts and sliders so make sure you add them for the comparison against CSL seats
          my recordsm estimtaed that CSL to Recaro XPG saved around 5kg and Recaro XPG to Carbon saved a further 3 kg
            thanks for the heads up mate
            weights not an issue for me, its all for fun :thumbs:
            I can vary by 30kg during the year... summer being the lightest time for me :hahaha:
              Having a large poo just before a track day can help too :thumbs:
                Your not much more than 30kg wet anyway.
                  Shimmy do You mean per seat of for both?
                  and which Volks save 2,2kg per wheel?? that's very interesting
                    He prob means the 18"s, but they all save a heap of weight ..
                    Roly has my old 19" set for sale on here currently - RE30's ( in matt gunmetal )
                      :hahaha:
                        Yes per seat
                        18 inch are lighter than 19 but 18 inch Cups are 0.5kg heavier than 19 so overall saving with my G2s is around 2.2kg per corner. Roly's Rays for sale will save nearly that as well
                        On top if that
                        SS backbox 12kg
                        Battery 7kg
                        Suspension 6kg
                        Seats 20kg (taking one out)
                        Rear seat and boot trims 20kg
                        BBK 5kg
                        Pollen filter 5 kg
                        Wheels 8kg (rotational)
                        Diet 20kg
                        Fluids 20kg
                        Puncture repAir etc 5kg
                          Yes per seat
                          On top if that
                          SS backbox 12kg
                          Battery 7kg
                          Suspension 6kg
                          BBK 5kg
                          Pollen filter 5 kg
                          Diet 20kg
                          Fluids 20kg
                          great that's what i looked for. Now just tell me which battery is 7kg lighter, suspension i guess KW V3? , seats understand, rear seat understand, BBK ok, fluids?? how can i get off 20kg on fluids?
                            No washer fluid and run with less fuel
                              Most of the weight reduction is from the dashboard back wards.
                              The tail is too light any way ! ! :bigcry::bigcry:
                              T$
