LUK clutch kits
    LUK clutch kits
    Am I right in thinking that luk clutch kits are the ones used from the factory on the CSL?
    Reason I ask is I've noticed clutch slur a few times on my CSL so think I'm going to have to replace mine.
    A guy posted a discount code on cutters today for eurocarparts, there advertising the luk clutch kit for £240.88 but with the discount code (jan20) it brings the price down to £192.70 so a good saving.
    If these are good what else would I need to buy to replace it or is this everything?
    :thumbs:
    not sure on your question Shane (although ive had two clutches by BMW)
    you prob know that the slur is almost never wear, always just bad adjustment by the actuator. Both my clutches were perfectly good but just got inot a habit oif slipping.
    If you get the clutch/gearbox taught again it normally puts it right unless the slipping has gone too far
      I've looked up what you've just said in the past mate but when I rang BMW they said it wasn't possible???
      It's not that bad but it is starting to get more frequent when giving it some, my cars only done 35k so was quite surprised when It first started slipping.
      Maybe another call to BMW then to get it adjusted first, any ideas how much they charge for this?
        tbh thats just rubbish mate, they're fobbing you off
        if its a warranty claim they ALWAYS send you away after teaching the clutch/gearbox again before they entertain repolacement
        try a diff dealer or a good indy up your way:smokin:
          Will do mate cheers.:thumbs:
            give murketts a ring,they have probably sorted more csl clutches than any other dealers.
              I'll try anything if it saves me replacing the job lot, cheers mate.
                Correct the LuK clutch kit is the OEM supplier. But listen to Shimmy, 90% of the time it's not a wear issue.
                As for re-teaching the adaptation - find someone with a GT1 .. it takes 5 minutes to reset all 4 adaptations.
                Show your service dealer this thread if they are too stupid to know what to do.
                This might be helpful for those using a third party software and don't know what functions to use: Middle box shows the service item, right box shows the functions to use
                  Thats great info thanks alot, is the GT1 gear easy to get hold of? I wouldn't mind that for myself.
                  :thumbs:
                    I fitted new luk clutch kit flywheel 1000 miles ago cost of £414, sod all wrong with existing only that thrust bearing had broke up into 3 pieces, all perfect now after gentle bedding in and smg reset. happydays...
                      Is that a all in price mate?
                        yes for parts did all work myself bit of a bar steward fitting took 4hrs all in, got the receipt somewhere, it was buypartsby clutchkit £138 +vat, flywheel £205 + vat hope this helps cheer steve
                          Bit of advice, buy the best clutch you can afford. Not the cheapest you can find.
                            Another bit of advice (from past experience) is that the clutch slur is caused by the SMG drivelogic not having the same biting point reference as what is actually on the clutch/flywheel. A proper calibration with the right tools will fix this in 30 minutes.
                            Also I've had a slur before thanks to a dodgy guibo, but that was accompanied by the worst undriveable judder from 1st gear starts.
